Timing?
Old Sep 9, 2014 | 09:37 PM
FilthyLucre's Avatar
FilthyLucre
Originally Posted by 78lowshovel
So leaving the line and at low rpm's there is a flat spot in acceleration, and a miss now and then. Plugs are gaped .040, points .018
Timing is advanced as far as plate allows but seems lik I needs to advance farther, can I modify timing plate so it can advance farther? How do I clean up the low end? Thanks
That's the wrong plug gap for points. The gap should be .028-033 The electronic ignition is set wider.
Old Sep 10, 2014 | 11:22 PM
78lowshovel's Avatar
78lowshovel
Copy thanks
Old Sep 11, 2014 | 06:27 PM
LilRosie's Avatar
LilRosie
Bingo........ point setting, my thoughts exactly.
Old Sep 14, 2014 | 03:50 PM
78lowshovel
Going to work on it as soon as the hawks game is over. Go Hawks!!
Old Sep 16, 2014 | 12:14 AM
78lowshovel
Gaped plugs at .030, reset timing, retarded a little bit from before accel pump seems to work just fine but still runs a little rough at low end. Runs super great while accelerating and in the top end.... Starts is 4 kick stone cold so that's cool.
Old Sep 16, 2014 | 10:57 AM
Joe12RK's Avatar
Joe12RK
good news - it's great when little adjustments make a big difference. it may be time to fiddle with idle or intermediate jets
troop
Aug 17, 2016 12:23 PM
maximuswaximus
Nov 24, 2013 10:14 PM
98glider
Shovelhead
Dec 15, 2010 05:31 PM
supr2nr
Ironhead
May 5, 2008 08:47 AM
Bluerose
Jul 6, 2007 08:16 PM
