Removing clutch cable on 2006 dyna low rider
Old Feb 25, 2013 | 02:09 PM
harbourside's Avatar
harbourside
Question Removing clutch cable on 2006 dyna low rider
im waiting for my throttle/idle cables and clutch cable to finish my ape hanger project. i havent started to remove the clutch cable yet but i thought id come here to ask for advice. i assume you need to remove the "six speed" cover to access the end of the cable etc. is it pretty straight forward or what? it looks like im going to have to remove one exhaust pipe as well to get at the cover but o well. anyone that can give advise on this id appreciate it.
thanks
Old Feb 25, 2013 | 02:31 PM
zimm's Avatar
zimm
Here you go:
Old Feb 25, 2013 | 02:35 PM
JRK5892's Avatar
JRK5892
little trick to re route it is if you tie a string to the end of the cable after you remove it, this way you can re tie it and use the string to pull the new cable back though, works great!
justmealwatts
Mar 27, 2020 09:00 AM
bauer4567
Dec 6, 2012 08:34 PM
Reaper_ggy
Jul 14, 2011 03:38 PM
boduke883
Jun 12, 2011 11:58 PM
bg3075
Aug 30, 2009 09:53 AM
