With a Bump in compression ....you may want to see about a upgrade for the ignition module also ..(if you don't have one already) ... to get the full advantage of the heads and cam ..an adjustable one would be best ...are you will have a very hard hitting and vibrating motor ....
if you want to sell the stock heads ...when your done ...i will take them !!!
Thanks for all the responses, Its a no brainer. Ill grab them and install. Having never removed Evo cylinders can I assume after I remove the heads just lift the cylinders enough to slip the wrist pin out so as to leave the piston in the cylinder. . would like to do the base gaskets to. (yes I have the service manual) and better start reading it.
That would be correct Dave. Just lift cylinders enough to push out the pins.... After you pull the cylinder heads off take a couple pieces of PVC three-quarter inch pipe and Bolt the cylinders back down. Both cylinders and check your piston how far down in the hole they are. You might be able to use a .010" base gasket to help pop the comp even a little more. Cometic is all I use.. it will actually help the burn with a tighter squish of around .035".
I was offered a set of New in the box SE Evo heads for real cheap. Id rather not change the cam again.
First off...define real cheap.
Originally Posted by Ruggs59
From what I read the SE head can be used with stock pistons and will raise the compression to 9.5. What's your thoughts on just removing my heads and bolting the SE one on? Any gain to be had?
You live in NY state...have you considered having the boys over at Hillside porting your heads to your exact specs?
