Help installed hammer 1275 kit and makes a noise like metal is hitting something
Old Oct 18, 2018 | 10:06 AM
Matthew Valinsky's Avatar
Matthew Valinsky
Default Help installed hammer 1275 kit and makes a noise like metal is hitting something
So i just installed my kit and i started breaking it in. Did proper warmups,broke it in 1 mile than 3 miles, than i started on my 50 miles. As i was riding 11 miles in i started to hear this noise sounds like a nut or something is hitting inside of the motor. This is what i did. I checked to see if anything was loose externally nothing seems to be loose. Opened the top covers to see if a bolt came off and nope all of them are on. I retuned it with the tune they gave me not triming the variables. I used the same oil but its filled. Would i have to use different oil ? Is it thining? Not sure what it is any help would be great.
Old Oct 18, 2018 | 10:51 AM
apache snow's Avatar
apache snow
Did you make sure the circlips were in all the way on the piston wrist pins Call Aaron or Dan and run it by them.
Old Oct 18, 2018 | 12:44 PM
John Harper's Avatar
John Harper
I'd call Hammer ASAP, they've heard everything.
John
Old Oct 18, 2018 | 08:41 PM
sorensentyler's Avatar
sorensentyler
Sounds like the motor is on it’s way to blowing up
Old Oct 19, 2018 | 08:03 AM
HotRod917's Avatar
HotRod917
Did u check the squish on both cylinders before final assembly. +1 on the talk to hammer comment
Old Oct 21, 2018 | 06:05 PM
ChromeSporty's Avatar
ChromeSporty
The holes for the rocker arm bolts are a bit larger than the bolts. The rocker arm covers have a bit of play back and forth before the bolts are tightened. What if the cover has been tightened and skewed in one direction enough that a push rod is sightly rattling against the frame or one of the push rod tubes??? Try loosening the covers and move them to a sightly different position. I remember reading this in a blog somewhere.
Z
Engine Mechanical Topics
18
Jul 2, 2019 11:21 PM
jasonlupo
Sep 26, 2017 09:05 AM
Grappa
Jul 2, 2015 03:48 PM
lhcstreetbob
May 7, 2009 10:56 PM
Batsy74
Shovelhead
34
Jan 3, 2008 02:38 PM
