Ticking Noise
Old Sep 26, 2017 | 05:35 AM
jasonlupo's Avatar
jasonlupo
Stage I
Default Ticking Noise
I have a 2014 Ultra limited with 28,000 miles when i lean to the left it makes a ticking noise. I use synthetic motor oil 20/50 I just started hearing it - bought it used with maintenance records bike has been well taken care of but this is my first long trip on it and rode it really hard the first day because of a delay in my trip. Don't know if y'all have ever heard of this noise before but its weird that it only does it to the left. any info will be helpful.
Old Sep 26, 2017 | 05:59 AM
Jemezcrusher's Avatar
Jemezcrusher
Once I started using Lucas stabilizer in my engine oil (25%) most of my valve train noise disappeared. Still have some at higher rpm' s with no load, but seems to be a normal amount
Old Sep 26, 2017 | 07:49 AM
voodoodrug's Avatar
voodoodrug
welcome
if it only happens when you lean to the left i would start by looking at other things besides the engine.
hears one for you to try,but you get the idea:try shifting foot pressure on the floor boards, have had that one stump me a few times,tighten shim...ect as needed.
Old Sep 26, 2017 | 08:02 AM
tpcowfish's Avatar
tpcowfish
Originally Posted by voodoodrug
welcome
And, or , try to put pressure on shifter with to ,or heal, worth a shot
Old Sep 26, 2017 | 08:14 AM
Veekness's Avatar
Veekness
I agree that this issue is likely external...shifter...jiffy stand....if you do find that the noise is in the rocker boxes, try a set of Rockouts.
Old Sep 26, 2017 | 08:58 AM
OldMike's Avatar
OldMike
If you lean the bike left and your body leans right, you might be hearing air cleaner noise or exhaust leak.
Old Sep 26, 2017 | 09:05 AM
Duracell's Avatar
Duracell
Check your wheel bearings
SportsterRider85
Aug 26, 2017 03:14 PM
roger scarcliff
Jan 28, 2015 07:39 PM
Old Road Toad
Apr 3, 2014 01:31 PM
missboy
May 15, 2011 10:25 AM
traveler
Exhaust System Topics
13
Jul 6, 2005 04:00 AM
