Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
STICKY SHIFTER
Old Apr 6, 2008 | 01:29 PM
santi's Avatar
santi
Default STICKY SHIFTER
I have 05 softail deluxe,I have a problem when i shift into second gear and all gears after that.The shifter will not spring back to the center postion.It has to be done manual. I called the dealer and they said, this is called a sticky shaft shifter. What are they talking about.
Old Apr 6, 2008 | 04:49 PM
Chief101's Avatar
Chief101
Default RE: STICKY SHIFTER
Hey
There is a thread on here about that. Had the same problem myself. Had to take the toe and heel shifters off, clean and lube the shaft and reassemble. Also, check the points on the shifter rod. Mine was ok, just cleaned it and lubed. After that shifting was fine again.
send a "PM" to Citoriplus.....I think he wrote the thread.
Good luck
seamus
Mar 14, 2014 04:29 PM
ashinc
Dec 8, 2011 07:55 PM
actorscotty
Sep 16, 2011 04:14 PM
busch
Aug 15, 2009 06:20 PM
JacktheBagger
Oct 2, 2008 09:21 PM
