Shift lever question
Old Jul 14, 2022 | 10:54 AM
coylizard's Avatar
coylizard
Default Shift lever question
I have an '09 Road King.
One year ago, I noticed loosening in the fitment of the toe (front) shift lever where it attaches to the shifter shaft. I found wear on the toe shift lever and on the shifter shaft where they join. I replaced both... with Harley Davidson replacement parts. The heel (rear) shift lever appeared intact and worthy and didn't require replacement.
Now one year and 4300 miles later, the toe (front) shift lever is loose again with evidence of wear and breakdown in the grooves where the shift lever fits onto the shifter shaft.
I keep the attachment bolts tight and inspect the fitment as a matter of routine in my regular pre-ride inspection.
I am surprised with the toe shift lever breaking down in such a short time and am disappointed that the local Harley dealership wants $55 for a new shift lever.
I understand the problem is not uncommon but am curious how long folks usually go before having to replace shift levers?
Thanks for your attention.
Old Jul 18, 2022 | 11:47 PM
Max Headflow's Avatar
Max Headflow
112000 miles on a EGC, 80000 on an 02 RK and 47 on a 17 RK, 65000 on a 09 FXDX.. Learn to check them and keep them tight no issues. Wiggle the levey, if its loose, torque it down. New ones will loosen in the few thousand mile simply because the fit ain't that great new.. Once bedded they seem to stay..
In your case, you should have probably replaced the shaft also..
Old Jun 6, 2026 | 11:00 AM
Robtattoo's Avatar
Robtattoo
These stop all the linkage slip problems, but you'll have to fabricate a new connecting rod. I made mine out of 5/16" stainless rod, heated & bent to shape. https://www.lowbrowcustoms.com/produ...qtiawSLXS9KzlZ
Old Jun 6, 2026 | 11:17 AM
touchdown's Avatar
touchdown
yep they are a piece of ****. I carry and extra one with me. Never used it for me yet but replaced 3 times for friends on the road. I just tell them to replace it with a new one for me. I did order one from JP I think it had a grease fitting on it 50 K no problems.
Old Jun 6, 2026 | 11:36 AM
Rounders's Avatar
Rounders
I put anti seize on the bolt to provide lube when tightening down. Plus I just like anti seize
Old Yesterday | 01:30 PM
eighteight's Avatar
eighteight
Use a longer bolt
Tighten it till it screams
Add a nylock nut on the protruding portion
Old Yesterday | 06:10 PM
dennyo's Avatar
dennyo
Me 2
Old Today | 04:31 AM
eighteight's Avatar
eighteight
Old Today | 06:58 AM
Rounders's Avatar
Rounders
Never seen a one piece. Before my time
Old Today | 10:50 AM
Taxgod4u's Avatar
Taxgod4u
