Intake manifold gaskets
Old Feb 13, 2025 | 10:23 PM
hammer6315's Avatar
hammer6315
Default Intake manifold gaskets
I am going to have my intake manifold gaskets replaced this Spring, on my '05 Sportster, and I am wondering what is a good brand? Thank you!
Old Feb 13, 2025 | 11:10 PM
OCSpringer's Avatar
OCSpringer
Cometic is the way to go on almost all the gaskets. James' push rod tube base gaskets are the one exception. I suspect a leak at the heads is more common than the carb side. I just pulled my manifold and where the bolt goes through the bracket I could see getting a leak if you're not careful as the bolt eats into the rubber right there.
Old Feb 14, 2025 | 06:30 AM
Architect's Avatar
Architect
Your bike is new enough I would start with HD, your local dealership might have them. They lasted 20 years the first time..........
Old Feb 14, 2025 | 07:31 AM
John Harper's Avatar
John Harper
I went with the HD seals just to be safe. There's a dealer about half hour away, so it wasn't a big deal to get them.
I'm sure the Cometic seals would be fine, too. I think the FSM says to use dish soap, but I used red grease without issue.
John
Old Feb 14, 2025 | 01:00 PM
hammer6315's Avatar
hammer6315
I had the bike worked on awhile back, and after ~6 mos. the problem reared its ugly head again. Happens after the engine is fully warmed up; when I crack the throttle, it falls on its face and pops back through the carb. After viewing some instructions online, I realize proper installation/assembly technique is important Thanks for the info.
Old Yesterday | 03:46 PM
PunkyDrewster's Avatar
PunkyDrewster
I was finally able to get this out!! Whew.
NOW TO BUSINESS: should I be concerned that the rear fuel injection line is rusty? I cleaned up the parts a little bit already.
Mattrat
Jan 28, 2025 05:48 PM
David Ostrander
Aug 31, 2020 09:14 PM
flhchaz
EVO
13
Jul 20, 2017 10:55 AM
WiscoKid
Screamin Eagle CVO Models
Sep 29, 2015 11:48 PM
eske29
Engine Mechanical Topics
Sep 4, 2012 03:52 PM
