Badlands tsm possible issue?
Old Feb 16, 2026 | 08:08 PM
SSBMX's Avatar
SSBMX
Default Badlands tsm possible issue?
I have a 2000 wide glide. I replaced my TSM with the badlands ATS-03-B. I’ve been running it for a few years with no issues. I was checking my trouble codes on my speedometer and noticed I had a D10set code! I have a brand new stator, regulator, and speed sensor. All I’ve been reading is that the code is open or short in the white/green wire that goes from the Speedo to the TSM. I found the white/green wire and realized it’s connected at the Speedo end and runs to the badlands module. When I look at the badlands module the spot where the white/green wire should connect is open. Is this correct? Am I seeing this D10set code because that white/green wire is not connected to anything? I’ll add a picture of the bad lands connector and a picture of the connecting end with the white/green wire
Bad lands connector
Bad lands connector
Connecting end from Speedo to badlands module with white/green wire
Old Today | 10:45 AM
HenryMorgan's Avatar
HenryMorgan
Stage II
Yeah, you’re probably not chasing a real fault here. On the early Twin Cam setups the white/green wire is typically the speed signal path that would normally run through the stock TSM/TSSM. With the Badlands ATS-03-B, that module replaces some of that logic, so certain factory inputs end up unused.
Cdex0614
Electrical/Lighting/Alarm
11
May 21, 2024 06:29 PM
Big Money
EVO
May 21, 2017 06:28 AM
mario medeiros
Jun 15, 2012 09:11 PM
jredd29
Sep 27, 2011 04:46 PM
straightshot
Aug 8, 2007 10:18 PM
