fuse for the speedo senser??????????HELP
Old Jun 13, 2012 | 06:49 AM
mario medeiros's Avatar
mario medeiros
Default fuse for the speedo senser??????????HELP
Have a 2000 eg tc just wanted to see if the speed senser is on a fuse as the wire from my senser was rubbing agaist metal and worn through the wire and the white wire touched the metal,i repaired the white wire,put it back on and now the speedo still will not work.Could the wire rubbing have shorted the senser?Thanks
Old Jun 14, 2012 | 11:56 PM
Mr. Mike's Avatar
Mr. Mike
Mario,
Is the speedo the only device not working? The fuse for "Accessory" feeds a few lines, but is interconnected on the speedo harness. If everything else works, i.e. rear lighting, rear brake lamp, then I wouls suspect the speed sensor. The service manual (2002 EG)says the white wire is the output side of the sensor with of course 12vdc the input side.
Old Jun 15, 2012 | 09:11 PM
mario medeiros
Thanks.i just installed a new sensor and all is good.Mario
Big Money
EVO
May 21, 2017 06:28 AM
Jameson
Mar 23, 2015 03:21 AM
jredd29
Sep 27, 2011 04:46 PM
dguse
Feb 1, 2009 02:47 PM
straightshot
Aug 8, 2007 10:18 PM
