With two races completed in the KOB race series, H-D has not been doing particularly well. To help close the performance gap between the H-D and Indian bikes, a rules change has been announced which will allow the H-D engine's max RPM to be raised from 7000 to 7200. Read more about it here:
Of course a 200 RPM bump isn't much but, in theory, I suppose every little bit helps. I just hope that that little RPM increase doesn't put the the H-D engines a bit too close to their kaboom zone. These races are pretty short no doubt due to the loads these heavy bikes put on their tires but I also wonder if the races are kept short because the engines have reliability issues. Lots of kabooms would be bad optics, that's for sure. Anyway, we'll find out if this helps or hurts H-D come the end of the month.
The current rules were the same last year and HD kicked ***, I think one Harley rider was DQ for exceeding the 7k rpm limit by 200 rpm's after tech inspection.
This year Indian is doing well and they’re gonna change the rules after two venues. I could go on but won’t.
Harley pulled all their Money out of Flat Track and Drag Racing to put it in the KOB series. This was after Indian kicked them around for a couple years in Flat Track. In Drag Racing the former "Harley" bikes are now Buell's. (There's nothing Harley or Buell about these bikes except the name. They all run Vance and Hines Billet Motors.) Just like NASCAR and Indy Car, the Road Race venues don't appeal to me. So Harley, Good Luck on the KOB Deal.
Indian Vance and Hines is eating Harley for lunch. They are ugly as heck, and I have test ridden few and the quality is not good to me. However they make more power, just the facts
If I had my way I'd get rid of the engine RPM limits completely. Come on, wind those suckers up until they puke. The net result would mean the manufacturers would have to do some serious engineering development to keep their engines in one piece. Let the best set of engineers and the best design win. Yeah, I know the Indian has much higher RPM potential with a (short?) 96.5mm stroke and an OHC design (not to mention full liquid cooling) compared to H-D's 114.3mm stroke and a flexi flyer push rod operated valve train but hey, this is racing. It should be Darwinian. Survival of the fittest and all that. :-)
Indian runs a power plus 112 motor that allows them the 7700 rpm max. Harley runs the 131 that allows them the 7000 rpm now 7200 rpm limit due to the displacement difference. Indians have more peak hp and harleys have more low end torque. On tracks with longer straight aways and big sweeping banks, Indians run away from Harley due to their higher speed. If they really wanted this to be apples to apples competition, they would limit each bikes displacement and hence rpm to the same specs.
