2018+ Softail Models Breakout
breather recall
Old May 10, 2026 | 09:17 AM
chunks's Avatar
chunks
Default breather recall
Apparently many 2025/6 models are subject to a safety recall due to a possible blocked breather port in the airbox
The good news is that if you have already (rightly) replaced that stock air cleaner on account of sheer ugliness and lack of performance, you are already in the clear
I'm doubly clear as I not only tossed that thing in the trash within a couple weeks of purchase, I also installed an external breather to avoid spewing any crap back into the intake.
Cant even check that stock part to see if it was blocked since it went to the dump last summer
Old May 11, 2026 | 01:36 PM
Big Al 59's Avatar
Big Al 59
Check this vid, they explain the issue and the way to control if your system is ok...
Old May 11, 2026 | 01:41 PM
chunks's Avatar
chunks
https://youtu.be/smPsDCHy07c?si=Q14tBQKD2OTjXdsG
Right. In my case it was irrelevant even though my bike was technically affectected because I replaced the stock air cleaner and added an external breather
like 2 weeks after I bought it.
Old May 11, 2026 | 01:51 PM
Big Al 59's Avatar
Big Al 59
Good for you...
I checked mine by blowing in the hose and it seems to work well, so no worries, I keep it like that whine I am under warranty...
Old May 11, 2026 | 08:05 PM
chunks's Avatar
chunks
Good for you...
Good for you.
replacing the air cleaner doesn't affect your warranty
Old May 11, 2026 | 09:44 PM
MesquiteFLD's Avatar
MesquiteFLD
I think it may negate the Extended Service Plan. The base warranty may not be.
Old May 12, 2026 | 01:40 PM
Big Al 59's Avatar
Big Al 59
Originally Posted by chunks
Good for you.
Thanks but I dont want to change it, I like the look and it works well for me...
Old May 12, 2026 | 05:05 PM
chunks's Avatar
chunks
Thats all that matters brother
Sash302
2024+ Center-Cooled Touring Models
Jul 30, 2024 06:48 PM
RG Pilot
Screamin Eagle CVO Models
Oct 4, 2023 10:04 AM
Gottoride
Milwaukee Eight (M8)
May 17, 2023 07:42 PM
Ken45
Jan 14, 2023 03:56 PM
AntonZ1
Mar 30, 2021 10:04 PM
