1993 fatboy bogging out
Old May 13, 2026 | 11:32 AM
DREDAY7880's Avatar
DREDAY7880
3rd Gear
Default 1993 fatboy bogging out
Everything was fine. I drove to go to dinner and on my way home. I left the light and when I go into first gear right when I’m about to switch over the second gear, the bike starts bogging out so I have to let go of the throttle and give it more gas to stay on, but I have to keep letting go and giving a gas in order for it to not turn off and I can’t get into the next gear because it’ll die before I even get there. Does anyone have any idea what it might be?
I can post a video if it would help
Old May 13, 2026 | 11:46 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Start simple and most obvious. Bad tank of gas.
Had our 2004 FI for 22 years. Only running issue it ever had. Filled up on the way to work. On the way home, it would not idle with out throttle.
Now it did run OK with enough throttle.
When I read your post, it appears to be getting too much fuel?
When was the last maintenance done?
PS.. Welcome to the HDFORUM.
Old May 13, 2026 | 11:55 AM
DREDAY7880's Avatar
DREDAY7880
3rd Gear
Gas is brand new and it didn’t do it on my way to dinner just on my way home and I didn’t do it the night before that when I went out at all
Old May 13, 2026 | 12:17 PM
Jackie Paper
Not sure 100 % what you are saying but it's not going to act up as soon as you start it on bad fuel at the station.
New fuel doesn't mean anything if it had water in it from there tank. In my case, it was pure ethanol.
The service station had to remove his two tanks. I was still messing with it for over a week when I noticed station was red and yellow taped. It made the papers.
There were hundreds of cars got it.
Now like I said, simple. If you know fuel is OK, start your next best guess.
If not fuel, maintenance or carburetor.. Maybe trash under needle, seat, or float if your lucky
Old May 13, 2026 | 04:28 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Does it feel like it is fuel starved or flooding [ smell strong of gas ] ? Carb will need to some love or the fuel screen in tank. Could even be the vacuum for the petcock valve leaking and not allowing sufficient fuel flow. I do not know if the 1993 has a vacuum activated petcock - so that was assumption on my part that it probably does.
Old May 13, 2026 | 07:05 PM
DREDAY7880's Avatar
DREDAY7880
3rd Gear
[QUOTE=MarlinSpike;22277698]Does it feel like it is fuel starved or flooding [ smell strong of gas ] ? Carb will need to some love or the fuel screen in tank. Could even be the vacuum for the petcock valve leaking and not allowing sufficient fuel flow. I do not know if the 1993 has a vacuum activated petcock - so that was assumption on my part that it probably
is it possible that it only happens once bike is hot ? Because the night before it didn’t do it at all, but I didn’t go That far but yesterday I stopped at a lot of lights on the way home so I think it got warmed up and then when I was close to my house about a block away and when it started doing it, but I just went out there now to try to diagnose it a little bit and wrote it around the block and it didn’t do it at all. Hopefully that helps with being able to diagnose it. *Rode
Old May 14, 2026 | 05:04 AM
bustergut's Avatar
bustergut
You could also try the Evo forum, for Softails 1984-1999: EVO - Harley Davidson Forums
Old May 14, 2026 | 07:01 AM
MarlinSpike
You have a tough one to diagnose, especially for us that can only use what you describe to try and take a shot at helping.
You need to try and determine - Fuel or electrical, as that area to try to trouble shoot. Things to check if you believe it is fuel related.
Fuel flow to carb
Petcock valve function
Fuel starvation or fuel flooding?
More info would help.
Any back firing, popping. Surging when it does come back from the bog. Smell of fuel. Fuel out of the vent tubes on the ground. Same condition if petcock in reserve position. All the vacuum tubes soft and still connected to the petcock. Is there a inline fuel filter? Those kinds of things, to try and get a direction to pursue.
Old May 14, 2026 | 07:45 PM
DREDAY7880's Avatar
DREDAY7880
3rd Gear
Fuel flow to carb
I will check all that and report back. Thanks for trying to help.
Old May 14, 2026 | 07:46 PM
DREDAY7880's Avatar
DREDAY7880
3rd Gear
yeah I could try that maybe I will if I can’t figure it out while posting in this forum.
