Adversary heated handgrip error
Old Jun 4, 2026 | 05:59 PM
alcors11's Avatar
alcors11
Angry Adversary heated handgrip error
I have a 2024 SG last fall I installed Adversary Heated Handgrips. I installed them myself. It was not necessary to have the dealer flashed in order to work. The IFCU recently showed an exclamation point the grips won't heat. They suggested / hinted that the install was bad. So I said I'd investigate (didn't want them charging me for hours of labor). This error is intermittent. When the icon does not show the grips work. Then all of a sudden the error shows up again no heat. Has anyone had the same problem? Any thoughts, comments, advice, or solutions? These grips are very expensive. They look great but right now they're just handgrips. I want to investigate fully before have more hundreds of dollars of dealer labor charged. Thanks in advance for any help
Old Jun 4, 2026 | 06:11 PM
mjwebb's Avatar
mjwebb
I had that error illuminate intermittently on my Adversary grip on my 24 RG, and they replaced the faulty grip under warranty and it was good from then on..they did the install and flash for ~$200, then warranty covered the part and labor for replacement
Old Jun 5, 2026 | 08:48 AM
maxxym's Avatar
maxxym
What is the code that it throws?
Old Jun 5, 2026 | 08:59 AM
mjwebb's Avatar
mjwebb
for mine, it was just like the OP had, grip symbol with vertical exclamation point .. I don't know about any code generated, just dropped it off for warranty repair
Old Jun 5, 2026 | 09:04 AM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
It should be covered under P&A warranty (need to determine what that is and if yours still is covered). Sounds like a bad grip. They will need to inspect to determine I'd imagine. As long as there isn't a pinched wire somewhere, I think it would be a warranty repair.
Old Yesterday | 09:03 AM
kentuckyarms's Avatar
kentuckyarms
I turned my 24 Road Glide in couple days ago for this exact issue. I pick it up today, so I'll find out what they had to do to it.
This just started. It has 36,000 miles on it.
Old Yesterday | 06:51 PM
kentuckyarms
Well, I got the bike back and they said the handgrips worked perfectly in the shop. Lol. I figured that would happen.
They did however flush the brake fluid and turned off the gold wrench. Cost me $155.
mjwebb
May 7, 2025 02:40 PM
fourburgs
Milwaukee Eight (M8)
Jan 2, 2017 02:21 PM
Fathertime500
Oct 22, 2012 10:05 AM
SteveinNKC
Nov 7, 2010 04:55 PM
thehueg
Jun 16, 2008 03:10 PM
