Rear brake/running light LED issue
Old Yesterday | 12:42 PM
dyno56ca's Avatar
dyno56ca
Question Rear brake/running light LED issue
Installed an LED 3157 in the GF's 2004 Sportster brake/running light, now when following her I have noticed that running light will flicker and sometimes even go out, with the standard 3157 there was no issue.
The brake light does seem to work fine.
Old Yesterday | 02:12 PM
eighteight's Avatar
eighteight
Some LED`s are too wide at the "flair" to fit the socket well, they vibrate and flicker
I went to these to avoid the issue
Old Yesterday | 08:09 PM
sirrom1's Avatar
sirrom1
Check that the wirs to the LED are not loose or broken.
I put one in mine, had the same issue. Found that the LED section was loose to the plastic socket. I took it apart and put it back together with siliconne; fixed.
Old Today | 12:02 PM
dyno56ca's Avatar
dyno56ca
I've put a normal 3157 back in for now, going out for a ride tonight with the GF will keep an eye to see if the regular bulb is also flickering.
eighteight the rear tail/brake light on the GF's bike uses a 3157 blade style bulb, it seems to plug in fine. I have the same LED bulb in my Sporty that I tried to put in her bike and don't have any issues.
sirrom1 was that just a 3157 bulb or the complete LED tail light assembly?
slowboy
Electrical/Lighting/Alarm
23
Mar 22, 2026 09:06 AM
flytrn117
Apr 18, 2024 09:42 AM
ratherdriveatitleist
Nov 3, 2020 03:37 PM
Oakley65
Apr 7, 2019 08:34 AM
kpb46
Nov 2, 2013 09:52 PM
