Vented; Non-vented. Does Anybody Know for Sure?
The whole point of this isn't so much that it was leaking, but why it was leaking. I had replaced the stock gas cap with a unit from Lowbrow Customs. It is a vented cap, and obviously gas can and does leak out of it. So the question I have, is the stock cap vented or non-vented. I don't seem to be able to find that info in the places I have looked.
I have ordered a Hogworkz flush mount cap, that is suppose to be vented. If you have used this cap, any feedback you have would be helpful. If the system needs a non-vented cap, then I will send this item back as it will probably leak also.
I have been filling to less than neck, and leaving cap loose. When I leave I will tighten and no more problem. But I did assume it was venting problem and didn't know if it was cap vent or tank vent not doing it's job.
My cap is vented which you can see. I'll have to check if it's plugged.
Yes, it flowed out on me also. It seemed to me that when the bike was running it was more pronounced. If the stock caps are non-vented, then I assume running a vented cap is going to be a problem.
For Harley-Davidson Low Rider S/ST models, the fuel system is equipped with an internal tank vent tube system. Because the motorcycle vents the tank via this dedicated hose, the stock gas cap itself is non-vented
Now at first I thought cap was loose, and I was just splashing fuel out ... But I finally saw it and it was no splash... It flowed. A LOT!
And sure I thought something wrong with cap, but the tank is vented, so how the hell is it pressurized? And I never have anything out of tank vent.
I also thought I was filling too full, and backed off a bit. But I've been filling it like that as long as I've had it. Something changed recently.
So back off on fill a bit, and leave gas cap loose to allow venting, no more problem. Tighten down after leaving. Yet the tank is vented, and who cares about this, and it shouldn't happen unless tank vent is cut off somewhere.
It resist liquid surge running and coming to a stop.
On California and maybe a few other States, the vent line goes into a carbon canister that has a vacuum line that when the bike runs, purges the canister into the intake .
You have a serious and very dangerous issue with your cap or the vent hose has somehow became mashed closed.
Your cap your ordered may be OK if it says it's OK for your bike. To some, vented and vented in only is the same.
