As stated in the title, does anyone here know the specification for fuel pressure on a MM injected 2000 FLHTCUI.... I have a pump in there, but its not specced for the bike. Its for a Ford truck, and I know the regulator on that breaks pressure down to 30PSI.... I dont know what the regulator is on the Harley, and I dont know what the output spec is on the pump. Bike is running with the pump slaved in, but before I button up the tank, I would like to know that its got enough pressure.... I have the proper pump on the way, but who knows when it will get here.....
The MM EFI system is lower, I want to say 43psi (3 bar), but that would be relying on my old man memory..
There was thread about MM EFI pressure recently. I mistakenly said I believed it was the same as Delphi EFI. I was corrected by someone much smarter than myself... I believe he said it was a 3 bar system.
