Stator or regulator, discuss?
Old Yesterday | 04:49 PM
caulk04's Avatar
caulk04
Default Stator or regulator, discuss?
2011 FLHX, 63K miles, good battery, no prior charging issues.
Couple weeks ago the service and battery light came on while cruising, voltage showed 12v for a minute then went back to 14. Wavered up and down for a little bit then mostly ran normal. Tested the regulator and stator to the best of mine and Google's ability, all appear good so it seems the issue is intermittent.
Today it did it again on my way to work and was temperamental on the way home. It's not constant enough to really discover much, but it SEEMED today that if it dropped voltage/stopped charging I could rev it up over 2500 and it would come back.
So my question, is it more likely the regulator or stator based on the symptoms I've noticed?
I imagine I'll end up ordering a whole kit from Cycle Electric unless there is more experience here to lead me elsewhere.
Old Yesterday | 05:27 PM
MURPHCC1's Avatar
MURPHCC1
I think it's the regulator.
I replaced my regulator when something similar happened to me.
And YES, go with Cycle Electric!!
Old Yesterday | 06:45 PM
kevin_n's Avatar
kevin_n
Here is a stupid question, had the same happened on my 04 ultra. Did you check to make sure the battery terminals are tight? Was on a trip with my wife and my bike started doing what you explained. Pulled into a Harley dealer and turned out that both positive and negative cables loosened up at the battery.
Old Yesterday | 07:34 PM
piasspj's Avatar
piasspj
Check and clean the battery connections and also the other end of the cables.
Old Yesterday | 08:31 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Here is how you determine what is the issue:HD Battery/Stator/Regulator Test
1. Battery Test:
The battery needs to be a fully charged battery that has been load tested to ensure proper readings. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Most places like Auto Zone, Advance Auto, and Pep Boys will charge and test motorcycle batteries for free. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, Measure DC Volts across the battery terminals (you should have a reading of approximately 13.2-15 DC Volts).
3. Check Connections/Wires:
Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there’s a failed component.
4. Stator Checks/Rotor Check:
Each of the following tests isolate the stator & Rotor, If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter leads.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multi meter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on meter.
Resistance should be in the range of 0.1-0.5 Ohms. (Reading will vary depending on system, check service manual for specification)
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on multi meter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Insure the regulator body is grounded or grounding wire is fastened tight to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multi meter to Diode Scale.
Place your Multi meter positive lead on each AC output wire.
Place your multi meter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multi meter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multi meter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multi meter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ∞
Battery charge lead AC output 2 ∞
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ∞
AC output 2 Ground ∞
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
RET_SCPO
Jun 18, 2024 04:34 PM
jweezy
2018+ Softail Models
44
Mar 4, 2023 11:46 AM
Goose_NC
Electrical/Lighting/Alarm
19
Aug 13, 2018 03:24 AM
Arjeje
General Topics/Tech Tips
Feb 18, 2016 10:21 AM
dunderwood
Jul 30, 2011 09:54 PM
