Can a tc88 be 180 degrees out of timing?
Old Jul 18, 2012 | 01:34 PM
keatingiv's Avatar
keatingiv
Default Can a tc88 be 180 degrees out of timing?
Quick question. is it possible for a TC88 to be 180 out. I was replacing my chain tensioners and inner cam bearings. i had just removed the outer cam, chain and mainshaft timing gears when my buddy decided to roll my bike foward. Now I am wondering if I go to line up the cam dots and the timing gear dots is it possible to be out 180. I know the gears have a key so they cannot be advanced howver. Advice would be appreciated the bike is a 2000 stock CV carb
Old Jul 18, 2012 | 01:48 PM
2black1s's Avatar
2black1s
No! Line up the marks and you're good to go.
The pistons will be at TDC twice for each cam revolution, but you can't be on the wrong stroke (or the 180 degrees out that you are questioning) because until the cams and timing gears are installed the piston doesn't know if it's an intake/compression stroke or exhaust stroke. Only once the cams, gears and chains are installed does there become an intake/compression stroke or exhaust stroke.
Line up the marks and you are assured that the cam timing is correct (within tolerance).
Old Jul 18, 2012 | 02:01 PM
V2Evo96's Avatar
V2Evo96
What 2Black says is spot on. I know this as he helped me with virtually the same question some time ago.
Old Jul 19, 2012 | 06:00 AM
keatingiv's Avatar
keatingiv
Thanks guys!! it worked phew . . .
Old Jul 19, 2012 | 07:02 PM
V2Evo96's Avatar
V2Evo96
Good for you -- there is always that 'breath hold' moment just when you press the starter switch....
Old May 7, 2026 | 08:23 AM
zfigoli's Avatar
zfigoli
4th Gear
What about spark? Doesn’t it only fire on the compression stroke?
Old May 7, 2026 | 08:52 AM
hattitude's Avatar
hattitude
You asked a question in a 14 year old thread and 2black1s hasn't posted since 2023....
So I'll answer your question..... Yes, and that is what the front gear timing marks are for.
When the front gear marks are lined up, it puts the rear cylinder at TDC, and syncs the crankshaft (pistons) with the cams (valves), so everything works as it should....
NOTE: On a Twin Cam engine, the cams also need to be aligned properly when set into the rear of the cam plate with their chain.
Old May 7, 2026 | 09:04 AM
CameraMan's Avatar
CameraMan
Is it too late to mention that he could put hotter cams in it?? IMWTK....
Old May 7, 2026 | 02:44 PM
zfigoli's Avatar
zfigoli
4th Gear
Thank you for the response. But what tells the engine to fire on compression stroke and that’s it’s compression not exhaust? If the crank sprocket is 180 out wouldn’t it fire on the exhaust stroke?
Old May 7, 2026 | 04:26 PM
GalvTexGuy's Avatar
GalvTexGuy
Newer models use camshaft position sensor. Older models use crankshaft positing sensor. Even older models use points.
