Air ride...modification to set frame on ground
Old Oct 20, 2014 | 02:00 AM
  #31
Jimstang's Avatar
Jimstang
Originally Posted by *Flea*
Cool idea, until you have to have to park on a slope and can't lean into it for stability.
Solution: Don't park on slopes or uneven ground
Originally Posted by Pudge211
Met a guy in Daytona while in daytona. He had a road glide and had to squares welded to the bottom of the frame. Bike had air up front and on the back. No kickstand. You had to bleed both front and back to get the bike to stand up by itself. Looked bad *** just sitting there next to all the other bikes. I have a pic on my old phone. I'll try to get it posted.
I'd definitely like to see that. Not sure if I would want hard stands welded to my frame for fear of clearance issues over speed bumps and such but post the pics if you can...any and all ideas are welcome.
Originally Posted by BakoOil82
Im working on mine right now. Have shotgun rear and using air pistons for the front from Misfit Industries. Front should lay no problem from what ive measured, but the rear is gonna be close. I have a low profile rear tire on its way and once that's on ill see how far away i am from the frame. Has anyone removed the bump stop? Curious if you get any lower without it. I have a machinist friend making me some standoffs to go on the bottom of the frame since the shotgun hangs a little bit lower than the frame. Ill post pics once i tear into it this week or next
Awesome dude. I wouldn't remove the bump stop on mine because the fender sits pretty close to the belt guard when it's lowered all the way.
Looking forward to seeing what you come up with. Thanks for chiming in here.
Old Oct 20, 2014 | 07:21 AM
  #32
*Flea*'s Avatar
*Flea*
I live near the mountains and have a lot of rolling hills in the area. Not ever parking on a slope would be next to impossible for me. You must be a flatlander that doesn't have to worry about such things. That's cool. But keep in mind that it also limits where you could travel on your bike. Then again, if you just beat around town and know your local terrain is all flat, then it's not an issue. I don't know you or where you ride. Some of us ride where there are at least some elevation changes, and some of us actually put a fair amount of miles traveling to different areas. I apologize if that doesn't apply to you and I offended you.
Old Oct 20, 2014 | 07:41 AM
  #33
24v's Avatar
24v
And some of us would be intelligent enough to turn the bike towards the uphill if we absolutely had to park on a slope.
Old Oct 20, 2014 | 07:42 AM
  #34
24v's Avatar
24v
You know that if you remove the bolts on the belt guard it comes right off, right?
Even looks a bunch better as well.
Old Oct 20, 2014 | 07:45 AM
  #35
24v's Avatar
24v
It will go lower without the bumpstop for sure. Things to watch for would be the belt guard, like mentioned above, the swingarm to rear fender contact, and tire to fender contact. The Softail suspension is approximately 3:1 ratio, and the bumpstop is probably 3/4", so there would be at least a few inches of lowering to play with there.
Old Oct 20, 2014 | 08:15 AM
  #36
Fat11Lo's Avatar
Fat11Lo
Like this idea and following the thread
Besides the issues already mentioned, one of the concerns I would have about removing the bump stops would be topping out the the cylinder of the Shotgun Shock, I wouldn't want the weight of my bike being held by the piston topping out against the housing of the shock. Maybe shave the bump stop to get a little more but removing it altogether doesn't sound like a good idea. Just my 2 cents
Old Oct 20, 2014 | 08:56 AM
  #37
Jimstang's Avatar
Jimstang
It's all good. I'm not offended at all. If I came off curt in my quick answer, don't take it the wrong way, it's just the military in me...I can be a complete jerk and not even realise it
It's funny that you say that...I've taken it off and prefer the look of it on.
As for the bumostops, I'm hesitant messing with those. I'd hate to bottom out and bend or break something. The roads here in England can be pretty rough in some places.
Old Oct 20, 2014 | 09:12 AM
  #38
Branner's Avatar
Branner
Bako & 24v: I'd recommend not removing the bumpstops. If you hit a big enough bump and bottom the suspension the swingarm could puncture your oil tank. There was a thread here where a guy shaved the bumpstops down but still left enough protection from bottoming . If I were to try to get my bike lower, that's the route I'd take. I'll try to find the thread and post the link here.
Old Oct 20, 2014 | 01:49 PM
  #39
24v's Avatar
24v
Yeah, I would not remove them on my bike. I was just answering the guys question.
Old Oct 20, 2014 | 02:21 PM
  #40
SoCalSoftailSlim's Avatar
SoCalSoftailSlim
I must say though, your bike looks just as cool on a kickstand. Perhaps more so. Classic.
