exhaust issues??
Old Oct 2, 2014 | 06:13 PM
triggerpuller702's Avatar
triggerpuller702
Default exhaust issues??
I just got a set of skirt blowers. I removed my old pipes, went to put these in and realized the ends are not tapered like exhausts I've done before. instead it gets larger, almost the size of the gasket. it doesn't slide into the port, but sort of rests on it. has anybody dealt with this? first harley in quite a few years but Ive never seen pipes that didn't slide into the ports.
Old Oct 2, 2014 | 06:15 PM
triggerpuller702
a shot with the gasket. the only way the gasket goes around this end is if it's stretched...
****, i was using my phone and had a few windows up. i meant to put this in the exhaust forum
Old Oct 2, 2014 | 06:28 PM
txphatboy's Avatar
txphatboy
Install gaskets into exhaust ports on the heads, then stab your exhaust headers into the ports. The exhaust gaskets are not supposed to fit around the exhaust headers.
Old Oct 2, 2014 | 06:37 PM
olongapo1's Avatar
olongapo1
I've encountered this problem a few times. Easy Fix. Test fit the header pipes (Without Gaskets) to verify that they will seat properly into the exhaust ports. If they do, you'll have to use Flat exhaust gaskets instead of the standard cone shaped gaskets.
You can easily find Flat exhaust gaskets through JP Cycles and I believe that Harley also sells them in their Scream'in Eagle line.
Old Oct 2, 2014 | 06:47 PM
triggerpuller702
i'll try. i tried to fit the pipe into the head without a gasket and it wouldn't even go in then.
edit... the pipes DO fit in the ports but the fit is very tight - almost paper thin gasket area. there's no way in hell the conical gaskets will work. are the screaming eagle gaskets that much thinner?
Old Oct 2, 2014 | 07:47 PM
olongapo1's Avatar
olongapo1
The SE gaskets are Not cone shaped. They are flat. Like a large, wide "O" ring
In my opinion flat exhaust gaskets do not seal as well as conical shaped gaskets. Occasionally you need to double stack them.
Harley4life323
May 14, 2016 11:10 PM
jude0808
Exhaust System Topics
Apr 13, 2016 06:31 PM
Landcruiser
Aug 18, 2014 11:56 PM
RA51
May 4, 2009 10:48 PM
Rowdy25
Sep 23, 2007 11:08 PM
