First I took the battery and had it tested Attachment 402332
And then took the bike and had it checked and every thing is ok ! I just replaced the stator and voltage regulator about 6 months ago . I must of have just got a bad battery .
raises a question?
Why did you replace the reg, and stator?
was it because of not charging?
Maybe you damaged the battery then ? just a thought
I purchased a Big Crank Battery from them a little over a year ago and the battery died I called them and they told me I was SOL there was a one year warranty buy another one! I am going to go to HD like I should have done in the first place at least they will last longer than a year. Sorry just really pissed
**** happens sometimes man...warranty is warranty , if it's up its up. I have seen many stories of stock HD battery going south and many of us have 4 year old big crank batteries. You never know but it sucks.
raises a question?
No the reason I changed the regulater and stator I was going a 2000 mile trip before I changed I had it checked and all was good but I didn't want to be 2000 miles out and then go out ! Been in the bike for 5 years
My bike don't set much I am in a MC and I put over 12000 miles on it this year . And on a battery tender through the winter .
Interesting, to me that sounds like you ride enough to keep your battery charged and even with a battery tender during the winter and your battery still failed, I find that kind of odd and I'd be wondering about it too if my battery only lasted 1 year, good luck.
I just replaced the battery in my 07 a month ago. As far as I know it was the original, I have only had the bike 3 years so is possible it was replaced previously. I have a buddy that owns a Parts Plus store and the battery is made by Deka even though it says Parts Plus on it same as Big Crank.
raises a question?
The stator and regulator are not parts that I'd consider changing in preparation for a long trip, seeing that it's easy and reliable to test these components - they're not wearing parts - what lead to this decision, and did you change other parts as a precautionary measure in preparation for the trip?
