Can you load test the battery? Also, as mentioned, make sure you cables and connections are clean and tight. How old is the battery? Battery life is about 3-5 years typically. Heat is what kills batteries and you don't typically notice a problem until it's cold where it requires more amps to do the work required.
Good luck..
PS, you should also make sure it's charging between 13.5 and 14.5 volts.
Well it finally happened. She left me stranded at work.
It was 27 degrees when I got out of the office and she wouldn't start. Had to push her into the warehouse and take a truck home.
35 degree's she starts.
27 degrees she won't.
Guess I'll have to start going out and start her once during the day.
As crazy as it sounds...turn the bike on and wait 30 seconds before you crank. It gives the battery time to "amp" up in cold weather. Another thing you might think of is a change of oil. 20-50 can get pretty heavy in that weather.
Good luck..
David
I'm actually taking it to the dealer to let them test it. It's still under warranty. The bike and battery are 7 months old. If the battery checks out I'll test the charging.
Thanks for the 30 second tip. I've not heard that.
I thought about the oil change today. Since we stopped using 50 and 60 weight oils and quit kicking these things to life I've kinda forgot about changing oil for cold temps.
Ever tried to kick start a Sporty with 50 weight oil in January? It's like trying to stir taffy.
After you looked after every battery drain issue,
I really think your battery has a kind of defect.
You could install a smart charger that you plug to your bike when you park it home (you just have to install a discrete waterproof plug on your bike that fits to the charger )
I leave in the north of france and winter as cold you think : our little batteries doesn't like cold temp at all... this smart charger gives just the amps the battery need to keep it in perfect condition.
It has a special function too that can give a second life to a nearly dead battery with a special charging program...
the following picture is just for example : what ever the brand is, they are usualy the same...
My Slim is the same reminds me of my old Shovelhead I had.
And I really think it's a oil weight issue when it gets cold, I always keep the Slim on a Harley trickle charger in the garage, I have gone out in 20 deg weather to the garage for a short ride and it will fire up.
I ran 60 weight in the Shovelhead and I had to keep it in the house in the winter if I wanted to ride it, and not to leave it set for over a half hour outside if I wanted to ride the Shovel back home.
Battery tested good. 318 CCA.
I guess testing the charging system is next.
If your battery is ok... it meens your charging system is ok too..
just put your both voltmeter tips on each side of your battery : if it shows 14v or more, everything is fine"...)
Your issue makes me remember me my first twin powered bike : an Aprilia RST 1000 FUTURA (rotax engine)... The first start of the day was always hard if the battery wasn't perfectly charged : it seems that the high compression engine and cold oil make start very hard...
