I have that short fender on the back not sure how long to go in the front.
Where did you get your rear fender cut? I picked up a used Rocker fender on Ebay a few months back and want to have it cut but have no idea who I should have do it.
Check Zodiac Performance, online catalogue!
There you can find all you need!
Thanks dude. I'll check them out
I did it myself mang! Right in my garage with a cutting wheel, some tape and a sharpie lol.
Minor hard at all
I think with the aggressive stance you got going with the clip ons you gotta stay with a short front fender. There's a bunch on eBay right now. I got mines from where I told you to get the clip ons from
I agree with you. A long fender would look out of place. I'm gonna look at that site you referred me to and then Flea Bay.
I did it myself mang! Right in my garage with a cutting wheel, some tape and a sharpie lol. Minor hard at all
I was considering doing that, did plenty of metal work for the airlines so I have the tools but wasn't sure how to deal with the multiple layers of metal welded together on the underside. If I cut it just forward of the original turn signal holes there's structure spot welded on the underside that seems to be reinforcement and shielding for the light wiring. What did you do with that so it wasn't visible after the cut?
I know exactly what you're taking about. I was worried about that same exact thing.
When I took it to the painter to get re-sprayed they filled it in on the edge so well that you can't really notice the difference in thickness on the edges.
I wouldn't worry about it dude. You won't notice it after its done.
I have an 08 Rocker C with short shots. The brake lever is too far away. thinking about floorboards. anybody here done that? Any tips or tricks?
Floorboards won't move your brake pedal any closer. However, you could add material to the front of the pedal to get it closer.
Remember when your parents got you a tricycle that was a little too large, so your dad added wood blocks to the pedals so you could reach them?
Same kind of deal.
I had a fatboy lo for a while and I could reach those, wouldn't it be the same setup? Couldn't I rotate the pedal back with the floorboards. I have thought about adding a block to the pedal??
is there any other way to reduce it or am I just hosed??
