Weird turn sig issue
Old Dec 11, 2014 | 12:24 AM
Daddy454's Avatar
Daddy454
Default Weird turn sig issue
Not getting any feedback on the electrical sub,so maybe I'll try here.
Just relocated my front sigs from the bars to the front downtubes.Cut and spliced the wires due to being ran through T-bars from previous owner,and didn't want to disassemble the whole harness-not that I didn't try.Anyway,now when I turn on the left signal,it blinks at a normal pace for about 4 flashes,then fast blinks.I've tried them numerous times,and it's always the same.I redid the rear sigs as well-just shortened the stalks,but did add about 2"of wire.The right side works fine,and I am still using the OEM sigs.Any ideas?I'm aware of the load equalizers,but would I need one with the stock sigs?2007 Softail Custom.
Old Dec 11, 2014 | 01:04 AM
Juiced_deuce's Avatar
Juiced_deuce
my guess is either a bad connection in the handle bar switch, with a slight possibility of the tsm.... turn signal module
Old Dec 11, 2014 | 08:03 AM
im's Avatar
im
What kind of bulbs in units.
Reason: A fast blink makes me think you have LED bulbs.
LED bulbs sometimes require a load equalizer.
Since you cut and spliced, is there a chance that you cut-off an inline load equalizer or rewired missing/bypassing it? or did you change a bulb?
Old Dec 11, 2014 | 10:09 AM
Daddy454's Avatar
Daddy454
Hmm...didn't take the switch apart at all.They worked fine before.
Old Dec 11, 2014 | 10:13 AM
Daddy454's Avatar
Daddy454
No LEDs.I replaced with regular incandescents.I did swap to amber bulbs,but that's it.Only splicing I did was to extend a couple inches from the connector since I cut out the section I left in the bars.
Old Dec 11, 2014 | 05:45 PM
TSheff's Avatar
TSheff
Does it start blinking faster while it is straight or only as you turn and are you actually seeing the blinker itself or dash light? Fast blinking with can be an indication of a bulb out.
Old Dec 11, 2014 | 11:42 PM
Daddy454's Avatar
Daddy454
Straight,or turning.Doesn't change.I first noticed it just testing the lights after I moved them.All four lights are good-new bulbs.Only on the left side.Weird.When I cancel the blinker,and turn it back on...same cycle.
Old Dec 12, 2014 | 08:39 AM
TSheff's Avatar
TSheff
Well sounds like you've checked pretty well. Just for kicks, have you swapped bulds left to right to see if problem moves or stays left? You have good contact and ground or they wouldn't light/blink. Are your rear also lit while running or in the brake light loop?
Old Dec 12, 2014 | 11:08 AM
Daddy454's Avatar
Daddy454
Tried that too.Rears are doing the same.They work,but the flash sequence is the same as the front when it starts fast blinking.......and only on the left side.
Old Dec 12, 2014 | 12:28 PM
TSheff's Avatar
TSheff
How about trying hazard - all 4 should blink at the same rate.
Just looked at the schematic and all signals and security go through the same module.
Depending on how important it is to you you could undo the connections you made for left & right and jumper to the opposite side that would confirm fault in module.
