Custom dynamic LED ringz
Old Dec 28, 2014 | 11:32 PM
Alain's Avatar
Alain
Default Custom dynamic LED ringz
Just installed these on my rocker. They are super bright.
I did not install the load equalizer and I'm not getting any hyper flash. I thought even rocker guys we're running load equalizers for these installs.
The only thing I noticed is that the turn signals now seem to self cancel a lot sooner than they did before. Does this have anything to do with me not running the load equalizer ?
Here is a shitty pic in my garage.
Old Dec 29, 2014 | 05:48 AM
greenbax's Avatar
greenbax
Wow that is such a grainy photo. You must photograph a lot of UFOs lol...
Old Dec 29, 2014 | 07:20 AM
Alain's Avatar
Alain
Lolol. You should see the photos I took the day JFK was assassinated ! Those came out a lot clearer.
Old Dec 29, 2014 | 07:24 AM
Iceman24's Avatar
Iceman24
Looks good - like how you have your bike mounted on a wall...
JK, as far as load equalizer IRT flash/signal cancel...guessing it does affect the signal(s) on your Softail as the voltage differs a bit. If you're OK w/it...not gonna hurt anything. Did you do the initial flash set-up w/the new LED signals (guessing yes)?
Old Dec 29, 2014 | 07:33 AM
Alain's Avatar
Alain
Iceman wish I could hang that sucker on the wall would allow me enough room to get another one lol.
Anyhow, no I didn't do any flash set up. I was under the impression that only the bikes with the new canbus system needed that. I just plugged them in and away I went.
What's involved with that initial set up? Just running the hazards for an extended oeriod of time ?
Old Dec 29, 2014 | 04:06 PM
greenbax's Avatar
greenbax
pic looks clearer - thanks! Very cool lookin
Old Dec 29, 2014 | 06:51 PM
Alain's Avatar
Alain
Took some better pics today.
Old Dec 29, 2014 | 06:55 PM
Alain's Avatar
Alain
Got the fatbob bucket with the Daymakers installed. I don't have a high beam capability with these auxiliary Daymakers but trust me you don't need a high beam. These are super bright.
I wired the headlights to the low beam wire so now when I hit the high beam they just shut off. Gonna use this feature when I start the bike to keep the Daymakers off while the bike is turning over. Plus ut looks pretty bad *** during the day with only the dynamic rings on.
Old Dec 29, 2014 | 07:01 PM
Alain's Avatar
Alain
This picture is pretty much useless but I always like to see a night picture when talking about lighting. So here goes mine.
Old Dec 29, 2014 | 07:34 PM
Gommee's Avatar
Gommee
Devil's Advocate
IIRC, the front signals do not require an equalizer installed. Only if you add LED to rear on Delphi system.
Can Bus, no equalizer required.
