Clutch issue 2008 crossbones
Old Jan 15, 2015 | 09:07 AM
xbonz's Avatar
xbonz
Default Clutch issue 2008 crossbones
Started the bike and put the bike in first getting ready to leave for work, did its normal clunk. Went to engage the clutch, roll throttle and ride off. No movement, no grab from the clutch. Tried cycling thru the gears, checking for engagement.... Nothing. Clutch lever feels the same. No unusual sounds from the engine or anything like that, any possible ideas on what it could be and looking for advice on how to troubleshoot. Appreciate the help.
Old Jan 15, 2015 | 09:16 AM
corliss@bakerdrivetrain.com's Avatar
So it won't grab in any gear? My first guess would be the transmission belt pulley splines are stripped. Clutch splines,maybe. Did you check the rear belt to make sure it's not broke.Put the bike in gear and see if you can roll it forward if there is no resistance something is stripped.
Old Jan 15, 2015 | 05:31 PM
xbonz's Avatar
xbonz
Thanks for the reply. So the bike is in gear and yes I get no resistance. Rolls like it would in neutral. Have not checked the belt as of yet. Guessing it might be time to break open the piggy bank and prepare for the worst.
Old Jan 15, 2015 | 07:02 PM
xbonz's Avatar
xbonz
Belt is busted... Is there anything else I should be concerned about our keep an eye on?
Old Jan 15, 2015 | 07:12 PM
dennyo's Avatar
dennyo
Yep. see if you can figure out why it broke , at least you were Home.
lowflyer
Custom Models
Mar 24, 2014 12:53 PM
MJ1731
Oct 3, 2013 07:22 AM
mxtrainer
Sep 3, 2012 06:37 PM
chez863
Jun 23, 2011 03:08 AM
Kyddworks
Jul 25, 2009 12:43 AM
