gas tank leaking from plug on top
it didn't look exactly like this. i had been trying to fish the clip out when i stopped to take the pic.
anyone had this happen, or heard of it happening? or hopefully just a one off fluke?
it was my first bit of a decent ride, just looping around the city, about 30mls. being it's winter i always top off the tank again since i don't know when the next ride will be. i was about to hop back on when i saw gas was steadily streaming from under the console. i didn't have any tools with me, and didn't know what i would have done at that moment anyway. i decided it wasn't leaking before, and coming from the top it couldn't leak long.
so for about 5 minutes i watched gas leak out and tried to wipe it up with the napkins at the gas pump. a few drops hit the exhaust and sizzled, which scared me some, but it finally slowed enough that i could wedge a napkin in the spot and stop the flow, then i rode home, about a mile.
it stopped by the time i got home, but it was late so i just put it in the garage...
...and mentally cursed it and thought all the harley rumours were true and called it everything but what harley named it
fortunately, the next day was still fairly warm so i got it back out and took a look at it, removed the console and saw the plug and metal plate it was in. first i tightened all the screws on the plate since they all seemed loose, but when i put more gas in i saw it leak out of the plug. it took a minute to see the clip needed to go on under the metal plate (like i said, the pic was me trying to fish it out at first) so all i had to do was siphon out some gas, take off the plate and put the clip back on from the bottom, and all was good. topped it off and took about a 10-12 mile ride with no leaks.
but i'd like to hope it was just a weird one off thing, and not something known for vibrating loose on occassion. i'd hate to have it happen in the summer with a hotter exhaust/engine, or happen at all. even though it was an easy fix, i'd hate to be wondering when it will happen next if it's a common thing. or if i need to do some saftey wiring or something.
so give me some reassurance. thanks for any help.
There shouldn't be any gas in there. I would guess it's the grommet the wires for the gas gauge go through is rotted. If you use gas with ethanol, ethanol weakens rubber over time.
the o-ring i'm not sure of. i thought it should have one, but after i took the plug out i felt it kind of inset in the plug, unless you mean there's a second one. but again, once i got everything back together it was good. i'll have to run by the dealers and see if i can get an ipb picture, to see what might be missing and know what the filter and pink fuel line you're talking about is. thanks for the help.
Yes, the screws have a torque spec and a pattern to tighten them.
