installing heated grips
Old Feb 18, 2015 | 05:42 PM
silly millie's Avatar
silly millie
2nd Gear
Default installing heated grips
2014 Harley Davidson Heritage
Where should I connect the grips' power wire? First attempt I connected to the wire that goes to front fender marker light but the grips quit working after a few minutes. I tested them not connected to the motorcycle and they worked great. Could I connect them to the headlight wiring? The grips are Avon and draw 3 amps. If not to the headlight, other suggestions?
Thanks
Old Feb 18, 2015 | 06:31 PM
Jersey Drew's Avatar
Jersey Drew
i would run them straight to the battery with a relay on a switched source.
Old Feb 18, 2015 | 10:24 PM
silly millie
2nd Gear
Thanks, Drew. He was trying to avoid having to remember to turn the grips off but I'll just have to think up some sort of reminder. He was also considering the tail light (I think). He discovered the headlight wouldn't work.
Old Feb 21, 2015 | 08:00 PM
Tyree's Avatar
Tyree
Not sure, but the Heritage may have an accessory plug under the seat. If not, the Slim has the DLC under the seat, one would assume the Heritage does as well. Harley has a plug kit to add an accessory using the DLC.
trackerman
Electrical/Lighting/Alarm
Jan 4, 2025 01:49 PM
Greg Di
2014-2024 Touring Models
Nov 18, 2017 04:51 PM
moloprintz
May 14, 2017 05:34 PM
newrider66
Dec 21, 2016 12:07 PM
INSteelersFan
Feb 5, 2013 11:45 AM
