S&S 98" big bore kit
Guessing that different size cams, how ever minute, will change the overall volume in the cylinder head space.
Is this the reason for your question?
I am not an expert by any means so I can't exactly get into all the technical aspects.
I got my 98" kit through hillside as some others have So I agree with giving them a call and having them set you up with a proven package.
Basically though, cams have certain compression ratios where they like to work well. I assumed the OP was just doing the big bore kit with no head work since he made no mention of it. If that's the case, the stock heads will only handle so much lift so that limits his cam selection.
He will next need to determine his riding style and the rpm range he rides in.
The easiest way to determine where the cam "comes on" is by looking at the intake closing time. Cams with early intake closing times (40° and lower) will be better for low end torque and cams with a later intake closing time will be best in the upper rpm ranges.
Usually those cams like high compression (10.5:1 and up) to see their potential though, so without headwork it would just be a dog.
Once again, I am no expert but have talked to a few engine builders and this is the basics that I got out of it.
Definitely talk to someone like Scott at Hillside or Kirby (prodrag1320). They know their stuff and will be able to steer you in the right direction.
Now just trying to decide the cams. I was set to go with the 510 from S&S, but have been reading a lot about Woods and Andrews cams.
The type of riding I do is just general cruising on the highway and back roads, don't ride much in cities. Never ride 2 up.
Thanks in advance.
