Does 21" wheel change geometry?
Old Mar 8, 2015 | 01:58 PM
Alain's Avatar
Alain
The front end is gonna feel heavier. In other words, turning your handle bars is gonna take more effort.
Like others said, it's not terrible, you'll get used to it. Once in a while you might feel a little instability at high speeds.
I rode my rocker with a 21 inch wheel (2 inches bigger than stock) for 5 years before I evened the bike out by using raked trees. The difference was very noticeable for me. I'll never go back to having an uneven ride.
Old Mar 8, 2015 | 07:51 PM
nikonf8's Avatar
nikonf8
Default 21 inch
The biggest difference I can feel it when stopped and maneuvering your bike like pivoting and things like that but on the road not much of a difference un less you do not have enough air in it
Old Mar 8, 2015 | 08:00 PM
amkaos's Avatar
amkaos
Well yeah, for me stock wheel size is just fine then..this yrs budget is probly burned anyway then
Old Mar 8, 2015 | 11:46 PM
SanJuanRon's Avatar
SanJuanRon
The geometry is slightly different -- but after a few rides you won't even notice the difference. I have a Heritage (21/18) and a Deluxe (16/16) and really don't notice a difference except on very slow speed maneuvers. I lowered the Heritage 1". I will be changing the Deluxe to 21/16 next year. SJ Ron
Old Mar 9, 2015 | 09:23 AM
Fat11Lo's Avatar
Fat11Lo
Originally Posted by tbonetony06
There are some VERY sweet bikes in this forum but I just cant see myself or my bike with anything other than these 16"'s I'm running. I just like all that big fat rubber out in front or me.
That's why I went with the 140/70/21, trying to keep that Fat Boy look. For some reason though I think the lower profile tires look better with the spoke wheels
Old Mar 9, 2015 | 11:43 AM
ADRENALINE RUSH's Avatar
ADRENALINE RUSH
me too! the whole bikes stripped down now, but i'll have to post some pics when i have it on.
Old Mar 9, 2015 | 11:44 AM
ADRENALINE RUSH
also if you go with a 21" wheel you might want to consider lowering the front to match the rise from the larger diameter wheel (adjust even more if you have the rear lowered).
Old Mar 9, 2015 | 01:15 PM
Fat11Lo's Avatar
Fat11Lo
I did 4 degree trees, lowering kit in the front and installed a Shotgun Shock at the same time of my wheel swap. I spent a couple of days with a square, a tape, an angle gauge and some string. Measuring, checking, double and triple checking all of the numbers to make sure my bike was safe on paper. Then it was test riding, getting the feel of the new setup and slowly testing the handling. It rides great, smooth at 80mph cruising and have pushed it up to 100 without any problem.
robatrak
Aug 4, 2024 05:05 PM
ElJayBird
Feb 23, 2018 01:16 PM
jamaicaholic
Jan 13, 2013 12:20 PM
Hammer107
Jul 29, 2009 12:42 AM
vicks96
Apr 18, 2008 04:52 AM
