Another ABS thread..looking for closure
Old Mar 9, 2015 | 03:34 PM
what_the?!'s Avatar
what_the?!
Default Another ABS thread..looking for closure
Hi All,
I've searched the forums and read all the flashing ABS light threads, and the wider 'net threads.
I havent found anything that is consistent though.
I changed my front wheel and now have ABS light flashing and then staying on.
ive checked the bearing for cleanliness, installation etc, and it all seems fine. correct way, etc.
in one thread someone said to pull the main fuse and let the computer reset- does anyone know if this works?
another thread said to get the SE tuner and because it flashes the ECU, it can also "re-set" any faults.
im confident that ive eliminated all but a faulty bearing and/or a faulty ABS sensor unit.
i need to replace my Vance and Hines FuelPak anyway because it is crap.
Its a royal pain in the butt to take my bike to the harley dealer for a computer reset and $40..so im trying to avoid that if possible.
Any ideas?
thanks.
Old Mar 9, 2015 | 10:43 PM
truckin's Avatar
truckin
Make sure you have a abs bearing in the wheel. Also anti size from the axel on the bearing or sensor will cause it.
Old Mar 9, 2015 | 10:57 PM
what_the?!'s Avatar
what_the?!
its an abs bearing, installed correctly.
went to the HD dealer who is a licensed HD servicer. They reckon that its the speed difference in the wheel.
they tell me there is no fix for it. i checked with another of their master techs and he said that they can stop the light, but then it renders the ABS to be dangerous as it wont lock when it should because they fool the ECU with a different speed ratio.
im just not digging this. HD make loads of money on after market mods, and built their rep on alot of that. and loads of wheels come with ABS encoded bearings. Why?..if they render the ABS either non functional or dangerous?
i ddont get that reasoning anyway, as the ABS should work on each wheel- not as a function of both wheel's rpm. it shouldnt matter what diameter it is.
i smell confusion. and considering i had no problem when i had a 21" front and an 18" rear, it just doesnt add up.
Old Mar 9, 2015 | 11:31 PM
truckin's Avatar
truckin
i would change the bearing if everything checks out ok, thats all thats different. i had 21/18 and now 23/18 and no issues.
Old Mar 9, 2015 | 11:36 PM
what_the?!'s Avatar
what_the?!
i just spoke to the national distributor about this. he reckons that they have had some bad bearings. and to change the bearing and then get back to him. otherwise the next step is the sensor itself, but he's telling me its got nothing to do with speed difference- the HD dealership doesnt know jack. (ill be advising them if/when i get this sorted)
thanks mate.
tim
PS it keeps amazing me how these dealers and servicers have such poor cause and effect skills..and they seem to be comfortable with "it just doesnt work for some reason".. rather than wanting to know why.
Old Mar 9, 2015 | 11:44 PM
truckin's Avatar
truckin
for sure, update the thread if that gets it.
bsdoig
Apr 10, 2019 03:18 PM
super48
Mar 4, 2017 09:03 PM
Dundlux
Nov 19, 2013 03:00 PM
Faststeel
Jan 28, 2013 03:25 PM
bohica
Nov 4, 2008 09:23 PM
