ABS light flashing!
Old Nov 5, 2013 | 11:48 AM
Dundlux's Avatar
Dundlux
Default ABS light flashing!
sup guys, just had my buddies install my new wheels on my 13 deluxe, but now the abs lights stays flashing… any suggestions on what it could be.. is it possible that i got the wrong bearings? should i just take it to harley and have them check it out? thanx!
Old Nov 5, 2013 | 12:03 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The wheel could be put on backwards putting the ABS bearing on the wrong side, or the abs sensor could be dirty or both. Or you could have a wheel that does not avhe an ABS bearing in it.
Old Nov 5, 2013 | 01:32 PM
MDivino's Avatar
MDivino
6th Gear
Foooof
Old Nov 5, 2013 | 01:51 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Seeing as it is single disc most likely no abs bearing. I'm so used to dealing with baggers.
Old Nov 7, 2013 | 08:32 PM
Dundlux's Avatar
Dundlux
before i installed the new wheels i had them powder coat it, and had the bearings pressed out, then pressed back in…do you guys think that could be the problem? can you press out bearings and get it repressed? or do i need to put in new bearings?
Old Nov 19, 2013 | 01:05 PM
oct1949's Avatar
oct1949
U will damage a bearing pressing it out if U put any pressure on the ID race. So it depends on how they were pressed out.
Old Nov 19, 2013 | 03:00 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Probably just needs to go to Harley to get them to turn the ABS light off. If the bike is turned on while the ABS is being bled the ABS light wills tay on. Did mine yesterday and no light as I did not turn the bike on during brake bleeding.
bsdoig
Apr 10, 2019 03:18 PM
Jaftica
Apr 4, 2019 10:19 PM
super48
Mar 4, 2017 09:03 PM
glock221
May 8, 2014 11:32 PM
Faststeel
Jan 28, 2013 03:25 PM
