V&H true duals & FP3
Old Apr 12, 2015 | 05:00 PM
swifty's Avatar
swifty
Default V&H true duals & FP3
Hey fellas.. I just took off my V&H 3 inch twin slash slip-ons off my heritage. And install a set of V&h true duals .The bike was tuned with a FP3 and I had no decal popping at all with the slip ons.. But with the true duals I'm getting a bit of decal popping.. I was wondering if any one with true duals using a FP3 had the same problem??????Im going to give V&H a call in the morning........swifty
Old Apr 12, 2015 | 09:06 PM
Harleyvetteguy's Avatar
Harleyvetteguy
Did you remap? You will have to remap for the new exhaust.
Old Apr 12, 2015 | 09:12 PM
swifty's Avatar
swifty
yes I did !!!! softtail dual standard baffles!!!!
Old Apr 12, 2015 | 09:18 PM
Harleyvetteguy
That is strange. If you have not tried auto tune I'd try that next. Mine runs fantastic from the canned tune they sent, so I won't be much help with the auto tune since I have never used it. V&H has great customer service. I'm sure they will be able to get it worked out for you.
Old Apr 12, 2015 | 09:46 PM
LACOUNTRYHICK's Avatar
LACOUNTRYHICK
Got them on my BO and mine does it!
Old Apr 13, 2015 | 04:46 PM
swifty's Avatar
swifty
The strange part is , This was the first ride of the season{ gas had stabil in it } when I filled up with 3.5 gals of fresh gas it was less popping... Is any of this making sense to anyone???
Also I called V&H and they said to burn a few gal of gas after that if it still pops to upload the map to them.
Old Apr 14, 2015 | 04:45 AM
Badbagger09's Avatar
Badbagger09
I have true duals with a fuel pak and have some poppin...
Old Apr 14, 2015 | 05:19 PM
swifty's Avatar
swifty
Did you try to auto tune it out????
Old Apr 22, 2015 | 07:03 PM
swifty's Avatar
swifty
OK time to update.... First ride with new exhaust and flashed with the fp3 had a lot of decal popping, Half way through the tank I filled up and had less popping . Came home checked my pipes and exhaust manifold clamps became loose. Re torqued to specs and a fresh tank of gas. Next ride I had a lot less decal popping , very little!!!! . Just wanted to update I did not auto tune. The canned map is just fine.. hope this helps someone....swifty
iambill
Exhaust System Topics
Feb 6, 2015 02:51 PM
leprechaun667
Apr 7, 2012 08:55 PM
serverpimp
Mar 3, 2008 12:07 PM
Anthony8858
Dec 23, 2006 10:15 AM
TKanaley
Jun 11, 2006 09:25 PM
