Do you have a load equalizer installed as your LED turn signals will not operate properly without it.
Pulsating lights is an indication that you don't have a load equalizer.
LED tail light does not require a load equalizer just turn signals require a load equalizer
Sorry guys, televisions cycle at sixty cycles a second, if you record a TV the cycle will be off that is what causes the funny waves.
In order to get this affect you need something that is cycling and catch it while off.
Video cycles at a much higher rate plus LEDs are DC so they do not cycle period.
If you see them flashing it is because they have a flashing module.
