changing tranny oil
Old Sep 16, 2005 | 05:49 PM
dj4016's Avatar
dj4016
Default changing tranny oil
Hey folks could use a little help out there! Want to change tranny oil on my 04 fatboy, there seems to be two locations where I can drain the fluid. The first option: A bolt with a female hex no O ring located on the tranny pan at the lowest portion. The second, there is a bolt just between the shocks located to the rear, a bolt with the O ring. Just wandering which location is the best to get the job done..
DJ
Old Sep 16, 2005 | 05:58 PM
billnourse's Avatar
billnourse
Default RE: changing tranny oil
The drain plug for the trans. on a Softail is between the shocks. It is a combination 1/4" allen and 5/8" hex plug. Use a regular 5/8" socket to get it loose, and then use the allen wrench to take it out. On my wife's Heritage, you can't get the plug all the way out with the socket, because the socket hits left shock. You should loosen it with the socket however, to avoid stripping the Allen insert if the plug is too tight.
Hope this helps.
Regards,
Bill
Old Sep 16, 2005 | 05:59 PM
MB's Avatar
MB
Hey DJ, it is the bolt up between the shocks.. You will need an extension on a socket to get to it initially, then you can use an allen wrench to back it out once loose (can't recall the size of the socket or allen, but same as used on crankcase drain). I had the same question on my 05'. I hadn't even seen the bolt between the shocks until someone told me thats where it was. mb
Old Sep 16, 2005 | 06:37 PM
dj4016's Avatar
dj4016
Hey Bill thanks for the fast reply,I kinda thought that was the bolt but it's good to here from someone who has done it before My manual was'nt that descriptive on exaclty where that bolt was. Thanks again DJ
Old Sep 16, 2005 | 06:42 PM
dj4016's Avatar
dj4016
Hey MB - Thanks for the quick heads up, I kinda thought that's where it was my manual shows the bolt but does'nt really show where it is located underneath
Thanks again DJ
tq745
Air Suspensions
Mar 21, 2020 12:25 AM
Rijan
May 16, 2019 09:46 PM
rquest
Apr 29, 2017 05:44 PM
dobeman21
Jun 3, 2013 07:26 AM
rolodog
Mar 9, 2011 10:28 AM
