Rocker boxes
Old Apr 24, 2015 | 05:38 PM
Rayland2's Avatar
Rayland2
Stage II
Default Rocker boxes
I have a 2007 softail standard I just recently changed the rocker box covers and I followed a you tube every step of the way and now I cannot get my bike to start it turns over fine but nothing I have gone through the whole thing twice and I cannot find anything thanks
Old Apr 24, 2015 | 05:47 PM
QC's Avatar
QC
Kill switch? Fuel?
Welcome to the Forum from Colorado!
Old Apr 24, 2015 | 05:54 PM
Rayland2's Avatar
Rayland2
Stage II
Default Won't start
Thank you any ideas
Old Apr 24, 2015 | 06:21 PM
Lou'sUltra's Avatar
Lou'sUltra
Welcome from Ohio
Old Apr 24, 2015 | 06:56 PM
Racer78's Avatar
Racer78
Is it injected? Did you pull the fuse to purge the fuel line pressure?
Old Apr 24, 2015 | 07:18 PM
RPMorey's Avatar
RPMorey
When I did my box gaskets, I put the intake pushrods in the exhaust position and vise/versa. Silver rods are for intake and black are for exhaust. (It can be tough to see the color difference.) If you did that, it can't make any compression. Pull the plugs out and crank it over. If you can hold your thumb over the plug hole while cranking, that is the likely issue. Move the plug wire ends away from your hands before cranking!
Old Apr 24, 2015 | 09:15 PM
Mike NY's Avatar
Mike NY
You said Rocker Box Covers, did you replace the whole Rocker box or just the covers?
If you changed the entire Rocker Box then there is certainly a lot more that could be wrong...
I know when I did my 95" the Rocker box gasket install was a little confusing and you had to make sure you didn't install the gaskets the wrong way....
Mike
Aussie Rocker C
Welcome Area Only
11
Nov 15, 2012 06:54 PM
krymis
Welcome Area Only
13
Jan 26, 2012 07:26 PM
UK RockerC
Nov 10, 2009 10:40 PM
Xuallus
Sep 18, 2009 10:37 PM
joe
Apr 20, 2006 09:44 AM
