Torque screws
Old May 6, 2015 | 08:02 AM
amkaos's Avatar
amkaos
Phillips screws are easy to cam out, straights are easy to slide off and cam out, allens can get rounded, Torex are just fine with me
Old May 6, 2015 | 10:07 AM
dfwhockey17's Avatar
dfwhockey17
Originally Posted by Mongo40
I have the right tools, not my first rodeo, problem is one in my rear strut, to tight an thread lock to boot wouldn't let it come loose! Was tuff getting the saddlebag bolts out an when I did they were coated in Locktite!
Sounds like your problem is the overuse of loctite and not the torx bolts....
Old May 6, 2015 | 12:00 PM
bigblock59's Avatar
bigblock59
Wait till the go the way of european cars and start using triple square.
Old May 6, 2015 | 08:24 PM
N-Truder's Avatar
N-Truder
Yeah, it's easy to use the wrong loc-tite.
I know the saying..."Tight makes right", but there are limits.
Is cross-threaded still torqued?
Old May 6, 2015 | 08:32 PM
Campy Roadie's Avatar
Campy Roadie
Impact driver with the appropriate size Torx bit.
Then after that, NEVER use Loctite in derby cover fasteners. I put anti-sieze on mine and torque them to the lowest setting because of the reduced friction.
Old May 8, 2015 | 12:05 PM
TriGeezer's Avatar
TriGeezer
Worse yet!! The rear frame member of the TriGlide has two T40 Torx Tamper Proof bolts that have to be removed to install a trailer hitch. They don't even do anything other than hold a nut plate in place, that is used for mounting the trailer hitch. WTF...why security tamper proof bolts? What are they trying to protect? Do you know how many hardware stores, auto stores, and home improvement stores I had to go to to get the tool to remove these?? I found one at the 2nd Lowes I visited.
What a PITA!!
Oh yeah, I replaced them with a standard bolt.
Old May 8, 2015 | 03:10 PM
Campy Roadie
Maybe they were trying to make it hard for someone to remove the mount and take the trailer, ball hitch and all.
Old May 8, 2015 | 05:19 PM
TriGeezer's Avatar
TriGeezer
Good point. Except I had to remove the mufflers to get to these screws. And didn't exactly slip off.
Old May 9, 2015 | 03:44 AM
Campy Roadie
So a cordless sawzall would be faster?
sincityharley
Exhaust System Topics
Feb 4, 2011 03:02 PM
dFREDb
Dec 4, 2008 09:07 PM
benwiggin2
Sep 14, 2008 12:30 PM
garcon
May 10, 2007 01:23 AM
bnoack
Aug 28, 2006 03:03 PM
