FXSB ignition switch elimination???
Old May 8, 2015 | 05:00 PM
Sgt Squid's Avatar
Sgt Squid
6th Gear
Default FXSB ignition switch elimination???
OK, I use the Accell Coil packs, so I eliminated the "grenade. Then I had the ingenious idea of relocating the ignition switch to the belt guard. That worked great until today when I finished installing my Shotgun Shocks. With the bike slammed, it just doesn't leave enough room for where I had it. So here is my question, can I eliminate the ignition switch all together and run a hidden switch, be it a push button, toggle or rocker? If so, can someone point me in the right direction? Thanks!
Old May 9, 2015 | 11:29 AM
Sgt Squid's Avatar
Sgt Squid
6th Gear
Wow! 302 views and not a single comment!
Old May 9, 2015 | 11:57 AM
Pigbacon's Avatar
Pigbacon
Wonder if you could convert it to use the key fob like the cvo's?
Old May 9, 2015 | 01:00 PM
dfwhockey17's Avatar
dfwhockey17
Convert it to a toggle and mount it under the tank out of sight...
Old May 11, 2015 | 11:03 AM
GMWhiteGuy's Avatar
GMWhiteGuy
I like the idea, a toggle under the speedo ( maybe in the empty hole ) would be pretty bad ***. Walk up to the bike and tap under the speedo and start her up! Just need to find a good way to mount it so it doesn't hang down too low, as not to be seen.
boysonch
Sep 9, 2012 07:12 PM
bosshoss41
May 4, 2012 08:20 AM
UT-rckr
Jul 21, 2011 08:43 PM
two tall
Apr 1, 2011 01:22 AM
F1J1
Jul 14, 2007 07:28 PM
