Ignition Replacement with a switch
Old Sep 8, 2012 | 04:47 PM
boysonch's Avatar
boysonch
6th Gear
Default Ignition Replacement with a switch
I have seen the ignition relocation kits online, but has anyone actually gotten rid of the keyed ignition and replaced it with a switch? Just curious.....if you have or have any ideas any info would be great. I have been thinking about how I can do this.
Old Sep 8, 2012 | 04:57 PM
chevy94ss's Avatar
chevy94ss
I replaced mine with a rocker switch hidden under the edge of the seat.
Old Sep 8, 2012 | 05:08 PM
John Harper's Avatar
John Harper
Should not be a problem, only three wires to move. I'd want to move mine if it was up by the neck too. Mine's an old one with the key above the cowbell.
John
Old Sep 8, 2012 | 05:47 PM
boysonch's Avatar
boysonch
6th Gear
Chevy94ss.......how'd you do it? I get the concept and I know it can't be hard, but just looking for a little bit of direction
Old Sep 8, 2012 | 06:02 PM
chevy94ss's Avatar
chevy94ss
I cut the wires going to the original switch, spliced together the acc and ign wires and connected them to one prong of the new rocker switch and then connected the last wire to the other prong. Voila
Old Sep 8, 2012 | 06:04 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Do you have any pictures of this?
Old Sep 8, 2012 | 06:13 PM
boysonch's Avatar
boysonch
6th Gear
Sounds easy enough. Where and how did you mount the switch? Pics would be great if you do have any
Old Sep 8, 2012 | 06:19 PM
chevy94ss's Avatar
chevy94ss
Unfortunatley i dont have pics. But once you have all the parts in hand its fairly simple. I should add that i did extend the wires about 8 inches so the switch would reach where i put it. I double sided taped it to the top of the oil bag just under the seat. It was meant to be temp placement but i kinda like it there
Old Sep 9, 2012 | 07:15 AM
Rog48's Avatar
Rog48
Never did understand the ACC position on our bikes.........what the hell is it used for?
Old Sep 9, 2012 | 08:13 AM
samhallnc's Avatar
samhallnc
I think I'm about to do this as well, my key is getting grooves on it and it's getting increasingly hard to remove the key. I can't remember for certain if it started before I installed the DK ignition relocation but I don't think it did. The only theory I can come up with for why it's happening is the relocated position causes the switch to shake with the engine (its mounted on the starter ground bolt if i recall correctly), which is cutting grooves in the key. Sometimes it takes a few minutes of shaking and pullling to get the damned key out of the switch.. I'd rather have a hidden toggle than deal with that.
