My FP3 Thoughts
Old May 15, 2015 | 06:41 PM
Aogmitch's Avatar
Aogmitch
Default My FP3 Thoughts
Well, I just bought my first Harley (in my sig) about 5 weeks ago. The bike ran well with the pipes, and unknown as to what, if any programing was on it. I did know that I wanted more from it, and the decel popping it had was driving me nuts. So, after some forum research, I decided to give the FP3 a whirl.
When it showed up, I hooked it up and loaded the tune for my pipes. First ride was much better than how it ran before, but performance wise, only felt slightly stronger. My decel popping was pretty much gone though, so that was a plus.
I then decided to experiment with the auto tune. After a short ride, it had a few green squares show up, but not many. Being unfamiliar with this, I hit the flash link. I shouldn't have done that yet. After it did its thing, the bike started having some running issues. In nuetral, blipping the throttle had a big stumble in it now. And the bike at times, would want to stumble and die when taking off from a start. Wasn't too happy by now. Once under way, the bike ran ok, but nothing impressive about the power. So I continued riding and ran through about a tank of fuel in autotune. Did 1 more flash about half way, and nothing really changed on that flash. Was really starting to get bummed with it.
Well today, I decided to flash it again as There were a lot of green squares filled. After that, I went ahead and hit the finish button. The new autotune file was created. I selected that, and it started loading the new map. When it was all finished, i threw on the helmet and started her up.
It sounded different this time. And throttle response was instantaneous in neutral. No more stumbling. Getting happier already. I then went for a spin. The difference is noticable right from the start. The bike has alot more power than it ever had, runs smooth and the decel popping is almost none existant. I'm still amazed at how quickly this thing will accelerate now, in any gear. Its a whole new bike now. Not sure if I want to mess with it any more, but I am sure I will. Feeling much better about this product now, than I was this morning.
Old May 15, 2015 | 06:45 PM
GroovusMagnus's Avatar
GroovusMagnus
Yep.
It's worth every nickel.
GM
Old May 15, 2015 | 10:13 PM
hOtroDD77's Avatar
hOtroDD77
Love mine. Still haven't gotten around to doing autotune yet...
Old May 16, 2015 | 10:12 PM
ILMFBL's Avatar
ILMFBL
I've had mine on my Lo now for a year now and love it. Funny thing about auto tune is it does just what you said every time, no biggy if you're aware of it coming. My advice when using auto tune is always go through at least two full tanks of radical driving at all speeds and rpm's as much as possible before flashing . And don't flash after each time you ride, just wait till your finished and your map looks good and flash finish. That way you can track your map better instead of loosing it every time you flash after a ride and then flash the finish. It's a pretty nifty little unit imo.
Old May 16, 2015 | 11:07 PM
Aogmitch's Avatar
Aogmitch
Started another autotune today. Plan was to do what you suggested and give it more time. Bike is still running very well. Only did about 50 miles today, but deffinatly had some pretty spirited info logged, as I was riding with a good friend.
Ridewva
2014-2024 Touring Models
50
Jul 27, 2015 02:46 PM
useR 564357348
Mar 31, 2015 09:16 PM
Scaffido
Sep 24, 2014 07:41 PM
powerman1972
Aug 20, 2014 01:21 PM
Big Twi$t
Mar 19, 2008 03:22 PM
