cam chain tensioners
Old May 16, 2015 | 08:39 AM
vanman59's Avatar
vanman59
Default cam chain tensioners
After 31,000 miles finally got scares enough to check cam chain tensioners. Virtually no wear. On phone so can't post pics. Only checked outside one. Didn't want to go any deeper than necessary. I was told the inside wears more than outside bit only a thousandth or less of wear on outside.
Old May 16, 2015 | 07:21 PM
Mike NY's Avatar
Mike NY
Well, you will never really know without seeing the inside one. Don't go by what people say it should be.
Since you had it open you should have just changed them. A little bit of work but at least you would have a peace of mind for a while.
What year is the bike? Pre 2007?
Old May 16, 2015 | 09:31 PM
vanman59's Avatar
vanman59
Default 2004 with pic
here is a close up pic
Old May 16, 2015 | 09:49 PM
1004ron's Avatar
1004ron
I would have changed them.
Why not put your rides detail in your sig?
Old May 17, 2015 | 10:03 AM
the blob's Avatar
the blob
I'd run em. Just ck the back one though. As long as they look ok, no sense in tearing out the rockers and cam plate. Just check em in another 10,000 or so.
Old May 17, 2015 | 11:10 AM
KumaRide's Avatar
KumaRide
Originally Posted by the blob
i'd run em. Just ck the back one though. As long as they look ok, no sense in tearing out the rockers and cam plate. Just check em in another 10,000 or so.
+1
Old May 22, 2015 | 08:56 PM
Rockhanger's Avatar
Rockhanger
My outer tensioner had less wear than your's is showing in pic.
The inner one was almost gone.
Old May 23, 2015 | 02:50 PM
Joe_G's Avatar
Joe_G
Here's a good description with pics on how to check the rear tensioner with a dental mirror by using a screwdriver and allen to hold the rear tensioner back from the chain without removing the pushrods, etc.
https://www.hdforums.com/forum/touri...88-03-rkc.html
Old May 23, 2015 | 10:52 PM
Harleycruiser's Avatar
Harleycruiser
People who say just replace then while your in there have no idea of what they are talking about, taking the cam cover off is not even a fraction of the work.
Check out the thread recommended, inspect the inner, then decide if they need to be replaced, and what direction you want to go.
Durango Dave
Engine Mechanical Topics
26
Jan 4, 2025 11:01 AM
whitepearl
Exhaust System Topics
Aug 25, 2009 02:15 PM
FLSTC4ME
Apr 26, 2009 05:32 PM
Professor
May 27, 2007 01:22 PM
HDF Tech
Oct 3, 2005 11:41 AM
