Front wheel problem!!
Old May 19, 2015 | 02:38 PM
katanaplanet's Avatar
katanaplanet
Default Front wheel problem!!
I took the front wheel of my heritage out to adjust my fender. Now I put everything back, the wheel does not move once I fully tighten the axle nut. It moves freely if I loosen it up. I put everything (spacer on one side and chrome bowl on the other side) the way it came out. What could be causing it?
Old May 19, 2015 | 06:22 PM
joebotics's Avatar
joebotics
loosen it ... then slowly start to tighten the wheel while looking at how the brake caliper / disks rub the brake disk... does the brake disk start to put pressure on the brake disk?... if so... perhaps the brake caliper is misaligned
also... are you using the torque wrench to tighten the nut? proper torque on the wheels is a life or death matter..
Old May 19, 2015 | 09:38 PM
katanaplanet
The wheel does not move even with the caliper off. Only way it moves freely is if the axle nut is hand loose!!
Old May 19, 2015 | 10:03 PM
QC's Avatar
QC
Is there a spacer behind the hubcap that may have become misplaced?
Old May 20, 2015 | 12:14 AM
ghostrider69's Avatar
ghostrider69
Sounds like you are applying inward pressure to the inner bearing race, the part of the bearing that the axle goes thru. Usually caused by one or two things. Wrong outer spacer or too short of an inner spacer. If you did not remove the bearings then it should not be the inner spacer, aka crush spacer. If the spacers are in the right place then it doesn't matter how much torque you put on the axle nut, the wheel should still spin freely.
Old May 20, 2015 | 07:22 AM
97 dyna lowrider's Avatar
97 dyna lowrider
Plus1 on that spacer. If all spacers are in the rim between the bearings it don't matter how much you tighten the axle. It should spin. It's a floating axle.
Old May 20, 2015 | 05:49 PM
JohnK-NJ's Avatar
JohnK-NJ
Check to see if the chamfer or radius on the face of the spacers is bigger on one side then the other side and face the bigger side in towards the bearings.
Old May 20, 2015 | 06:24 PM
katanaplanet
Johnk-nj You nailed it!!!
Old May 21, 2015 | 02:05 AM
user 46092's Avatar
user 46092
Yeah, it had to be the spacer.
rdondes
Feb 14, 2014 03:45 AM
byaj
Sep 17, 2012 11:30 AM
gli.der
Mar 28, 2010 10:23 PM
MICHALISLARNACA
Jan 10, 2009 04:47 AM
ctmedic
Apr 28, 2008 05:49 PM
