damn batteries
Old Jun 3, 2015 | 10:16 PM
pat.h's Avatar
pat.h
Default damn batteries
Gone through two batteries. i have a fatboy, 04 which is an 88, but now she has a big bore kit, 96, so im thinkin 310cca just doesnt cut it anymore. If the battery is like 99% it wont fire her up. The security brings it down enough that 3 days later i gotta jump it. I think its poor choice of a replacement battery that doesnt compensate for the added compression. According to the testing of the charging circute by the book, she is recharging 12.75, right on cue. I think i picked a poor choice of battery last time
Can Someone point me to a "non 300dollar" battery, perferably made in the usa
Old Jun 3, 2015 | 10:49 PM
woodman's Avatar
woodman
Throttlexbatteries.com is what I use. Made in USA by Penn
Old Jun 3, 2015 | 11:27 PM
Next In Line's Avatar
Next In Line
When I had my 88 to 95 bore kit w/ 203 cams, the stock battery worked fine. Even after the bike sat for 3 weeks, it started up no problem.
3 days seems pretty fast for it to die even with the alarm. Have you checked if you have a parasitic draw?
Old Jun 4, 2015 | 07:26 AM
pat.h's Avatar
pat.h
No clue how to check it. Never thought of it. Thought cheap battery, didnt like the ct winter not bein trickel charged.
Old Jun 4, 2015 | 08:54 AM
oct1949's Avatar
oct1949
When mine went dead 3 yrs ago I went with one from battery plus..
I went with the BS-Xtreme, it has a 1yr warrent but for a $30 more the USDuracell has a full 2 yrs..
http://www.batteriesplus.com/product...to-2012/1.aspx
So far it's never failed with the Andrews 26 cams I have, remember some cams have a high CC and high compression pistons or heads can put a lot more strain on the battery and starter that the stockers.
Old Jun 4, 2015 | 09:04 AM
Next In Line
https://www.youtube.com/watch?v=66m_BH_szTI
Old Jun 4, 2015 | 09:28 AM
1plumr1's Avatar
1plumr1
Bet there is some sort of draw on the Battery. Battery in my Ultra with 95" and 203 cams never had an issue starting even after sitting for a couple weeks with security on. Time to start testing circuits.
Old Jun 4, 2015 | 09:31 AM
pat.h's Avatar
pat.h
Great, havent done anything to the bike in 4 years so who knows where it is, nice video, abit evasive in "garage hunting" with homeowner tools.
Old Jun 4, 2015 | 11:45 AM
Warp Factor's Avatar
Warp Factor
The charging voltage is 12.75? Or is that the battery voltage?
Old Jun 4, 2015 | 01:28 PM
Snowyone's Avatar
Snowyone
Default Charging
The charging voltage stated is not enough. Your charging system should be in the high 13's with the engine around 2k. A set of compression releases might be a plus to. My 02 RG with a high compression 95 needed them to be easier on the starter and battery. It would start without but when hot would require several tries at the button before kicking over before installing the compression releases.
