replacing crossbones wheels.
Old Jun 24, 2015 | 04:22 PM
musicnbikes's Avatar
musicnbikes
Default replacing crossbones wheels.
Has anyone replaced the 17" rear wheel with a 16"? If so, do you have any photos?
Thanks.
Old Jun 24, 2015 | 08:47 PM
Slamed Slim's Avatar
Slamed Slim
Let me know if you wanna sell your 17x200?
Old Jun 25, 2015 | 10:24 AM
sober1's Avatar
sober1
The XBones rim and tire setup is perplexing to me; a 16" front rim with 3/4" axle on a de-raked(for lack of a better term) springer front end with a 17" 25mm axled rear. Kinda like the design engineers at HD threw a set of shackles on the old Chevy Nova single leaf suspension to jack the *** end upto make it look cool, regardless of handling. Anyway, after parking mine last fall due to death wobble, I began studying the XBones overall suspension/chassis set-up. Had I done this research first, I'd probably have passed on the XBones. My preliminary thoughts are the lowering kits I installed on the springer and rear shocks exasperated a poorly designed chassis.
So, to answer your question directly; NO - it looks like I'd need to swap out the swing arm for a 3.5" 16" rear rim swap. The tranny sprocket width is probably fine as it looks like it's a one size fits all. I'm just guessing here, but I believe we would need to stick to a 200mm 6.5" wide rim, otherwise we're asking for headaches.
Old Jun 25, 2015 | 10:45 AM
dfwhockey17's Avatar
dfwhockey17
We usually put 18x5.5" rear wheels on customer's xbones here. These have all been done when doing a 21x3.5" front wheel as well....If you wanted a 16" rear there are 200mm tires available so you could make that happen if so desired.
Old Jun 25, 2015 | 11:55 AM
sober1's Avatar
sober1
I know larger front rims are commonplace as well as same size fore and aft. The 17" rim was/is a feeble / cheap attempt by HD designers to help this stock 96" pig launch from a dead stop with its 2.79 final drive ratio, otherwise I see no logic in pairing it with a 16" front on a de-raked front. As for larger front diameter me thinks it would equate putting a tube axle on a ****** for better rearward weight transfer for leaving the line in a hurry.
And on a XBones I'd stay with a 200mm as there is a slight offset built into the 200mm swing arm. Just my 2 cents.
Old Jun 25, 2015 | 12:48 PM
musicnbikes
Thank you all, for this, I may have to pass on the crossbones, and look at the heritage classic springer, instead. I would like to hear more about the death wobble.
Old Jun 25, 2015 | 01:13 PM
sober1's Avatar
sober1
search it here. mine is probably due to my lowering my XBones like I said earlier post. death wobble occurs at speed where when you are only using one hand on bars and bike begins to violently shake. various reasons alone and in combination is the culprit with a million and one alleged cures. I chased mine from the 110TH until fall, then just parked it. trying to get back on the road wobble-free
Old Jun 25, 2015 | 01:21 PM
musicnbikes
I'm supposed to go text ride one in a few days, I will check for that. If it wobbles, I'll leave it there. Thanks, for the information!
Old Jun 25, 2015 | 01:31 PM
sober1's Avatar
sober1
Every time mine wobbled, placing both hands on bars and SLOWLY rolling out of throttle would calm her back down. Mine first showed up at 58-60MPH on deceleration. Just be smooth and relaxed to steady it back up. Like I said research it plenty first so you can thoroughly check for it and know what to expect and how to safely react to it.
SuperFastGlide
Jun 19, 2012 09:20 PM
kozy22
Dec 22, 2011 12:27 PM
bald1der
Jul 30, 2011 04:43 AM
rick
Mar 27, 2009 05:54 PM
sycle1
Jul 20, 2008 03:30 PM
