Help please: rotate bar risers 180 degrees?
Old Jun 28, 2015 | 11:40 PM
Jetfever's Avatar
Jetfever
Default Help please: rotate bar risers 180 degrees?
I posted this thread in the Tech and Mechanical forum, but there was no response, so I'll try again here:
I want to move the handlebars on my Softail "Slim Boy" forward, (away from my body) for more arm room while riding. I thought about cutting an inch or 2 from the end of these black "hollywood" bars.
Question: Can I just rotate the bar risers 180 degrees? This would move the bar about 1 inch forward, since the risers have @ 1/2 inch "pull back".
Has anyone cut an inch or two from the Slim handlebar ends?
I have the service manual, but I can't tell if there is some kind of "clock" or notch to prevent me from trying rotating the risers 180.
Thanks, Steve
Old Jun 29, 2015 | 12:41 AM
Next In Line's Avatar
Next In Line
If you are planning on rotating the bars anyways, you might as well see for yourself.
Worse case scenario is you have to undo the work because it won't work.
Old Jun 29, 2015 | 11:25 PM
Jetfever's Avatar
Jetfever
Bump. Has anyone cut an inch or 2 off the Hollywood bar ends?
This is not in the service manual either.
Old Jun 30, 2015 | 01:10 AM
asputin's Avatar
asputin
I rotated the risers 180 on mine.It was easy but didn't do much. I didn't cut the ends though.
Old Jun 30, 2015 | 02:41 AM
EvoSpringer's Avatar
EvoSpringer
Your handlebars are indented for your wires at a certain place and if you cut off an 1" or 2" you are gonna have to reindent your bars for your wires or they will get pinched in your housings when tighten everything back up
Old Jun 30, 2015 | 06:30 AM
cocky's Avatar
cocky
+1 on the indention. Learned the hard way with non HD bars. Ended up Dremeling a slot in the switch collars for wires to exit. Not clean, but worked ok.
Old Jun 30, 2015 | 08:39 AM
Jetfever's Avatar
Jetfever
Thanks, Guys! Post 4,5, and 6 are VERY helpful!
This information is NOT in the service manual.
Steve
underwhelmd
Aug 18, 2018 10:25 AM
Jetfever
General Topics/Tech Tips
Jun 29, 2015 10:23 AM
JCAPPS29
May 26, 2015 03:05 PM
jambsportster
Jan 3, 2014 09:31 PM
eleutheros
Apr 13, 2007 10:49 AM
