Heat affecting my gear shifting
Old Aug 10, 2015 | 09:23 AM
cbaywolf's Avatar
cbaywolf
Default Heat affecting my gear shifting
During the last 3 weeks, I've noticed that it's getting very hard to shift between first/second and second/third gears. It seems to get worse as the engine gets hotter, and seems to happen more when the temperatures are above 90 degrees (thus the engine is running hotter). It's also getting very hard to shift into neutral while the bike is running.
Clearly I need a clutch adjustment of sorts- but is this normal that it's happening more than hot? Is this a symptom of something else (oil breaking down)?
Old Aug 10, 2015 | 09:46 AM
Chaffeekid's Avatar
Chaffeekid
Hey had the same problem, check the freeplay (not the same as foreplay ) at the clutch lever. Look close, you should only have about 1/8 inch of movement prior to feeling resistance.
Watch the clutch cable, it may also move, take that into account also when looking for free play.
Pull down the rubber boot on the clutch cable, use a 9/16 and a 1/2 inch wrench, loosen the lock nut and take all but 1/8 inch of free play from the cable. If you over adjust or make it to tight, the clutch will slip under acceleration, if that happens, readjust until it doesn't. But, if you are careful it will not.
Now if that doesn't help, then you need to remove the derby cover and adjust the clutch itself, for that you will need more instructions or a service manual.
My Heritage was doing the same thing, I could shift into neutral before the engine warmed up but after it was hot, couldn't do it without shutting it down first. After adjustment, no problem.
Hope this helps, ride safe.
Old Aug 10, 2015 | 10:04 AM
cbaywolf's Avatar
cbaywolf
I was thinking that I had more freeplay than I remembered... Is that a function of the cables stretching out over time? I'll have to give that a try- thx.
Old Aug 10, 2015 | 10:39 AM
mdm's Avatar
mdm
https://www.hdforums.com/forum/prima...-easy-way.html
Adjust the clutch first (when cold), then adjust the cable.
Old Aug 11, 2015 | 05:35 AM
Valdemar's Avatar
Valdemar
Old Aug 11, 2015 | 08:40 AM
cbaywolf's Avatar
cbaywolf
Thanks for all of the info- I started by adjusting my cable last night and it made a world of difference. I can now shift with ease, and I'm able to find neutral again. I'm not going to go inside the derby at this time, but that video was a great tool for if I ever need to go that far.
Old Aug 11, 2015 | 10:24 AM
oct1949's Avatar
oct1949
Cbay.. adjusting your cable needs to be done to get the right amount of play in your cable, but-- it does not adjust your clutch pack at all...
you still need to adjust your clutch inside the primary.. usually a new bike needs it at the 1-5-and 10 k services.. then about every 10k or so thereafter to keep the clutch properly adjusted .
Old Aug 11, 2015 | 11:59 AM
cbaywolf's Avatar
cbaywolf
I guess I'm not clear on when I actually need to adjust the clutch inside of the primary cover (assuming it's not the proper interval to adjust it).
Just adjusting the cable did fix my issues of not being able to shift into neutral (when running) and very hard shifts. My cable was too far out with about 1/4" to 3/8" of free-play as opposed to the 1/8".
I just had my clutch adjusted at the dealer last November at my 5K service- and I'm at about 8K right now. I'd rather not open it up if it's not necessary.
Old Aug 11, 2015 | 12:17 PM
mdm's Avatar
mdm
The proper interval to adjust the clutch pack is determined by when shifting issues develop. It's not a time or miles issue, it's a wear issue.
The clutch cable doesn't really stretch that much. The cable develops slack because of wear in the clutch discs. To properly adjust the clutch you start with the clutch pack and then the cable.
Old Aug 11, 2015 | 12:34 PM
EagleRay's Avatar
EagleRay
Had exactly the same problem after I changed to chrome braided cables...after 2 hrs ride in stop and go traffic I couldn't get her in neutral at all and shifting became really tough...too much slack in the clutch cable. Got the clutch cable adjusted and everything has been fine since....
griffsyj
Nov 29, 2012 09:06 PM
nightie
Aug 24, 2012 09:51 AM
lakegeorgia
May 3, 2012 08:31 AM
WIDERGLIDER
Aug 30, 2011 05:41 PM
sledhead140
Jan 24, 2011 02:37 PM
