Compensator thoughts
Old Aug 16, 2015 | 09:30 AM
casadelray's Avatar
casadelray
Default Compensator thoughts
2007 Fat Boy, 20,000 miles. Bike starts great when its cold. Run it for 20 minutes stop, (achieve operating temp) and try to restart. Back fires, misses, and sounds like crap. Dealer says compensator is worn, common with early 6 speeds, $500 plus labor. FML
I see how the compensator works and understand how its responsible for my problem. But I'm developing a distrust for HD items. What compensators are best? Why? Anything else I should look at when I have it torn apart?
Old Aug 16, 2015 | 09:37 AM
Juan L's Avatar
Juan L
Moderator
<p>Baker compensator will solve your problem......</p><p>http://bakerdrivetrain.com</p><p>You can talk to Mark@ Baker Drivetrain&nbsp;who is on here</p>
Old Aug 16, 2015 | 09:40 AM
Next In Line's Avatar
Next In Line
The compensator is part of the primary assembly. It has no effect how the engine runs.
Find a new dealer or a competent indy.
Old Aug 16, 2015 | 10:09 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I had my compensator go out on my '13 Blackline after 10k. At least it was under warranty. But it made me wonder why it happened and so soon.
Old Aug 16, 2015 | 11:27 AM
hattitude's Avatar
hattitude
If you need a compensator, I would try the Baker over another HD part....
BUT....
You'll have to please explain to me how the compensator causes backfires, misses, and makes your engine sound like crap..... as I read your explanation of the issues, the compensator has nothing to do with those issues...
Either you misunderstood the dealer, you are not describing the symptoms accurately, or your dealer is an idiot.....
Old Aug 16, 2015 | 09:46 PM
casadelray's Avatar
casadelray
Okay, confusion on how the compensator effects the bike. First, the bike runs great and starts with ease when its cold. The problem lies in starting the bike when its hot. During subsequent starts when the bike is at operating temperature, it misses and backfires several times until it lights off. The stock compensators become worn and when the starter is turning over the primary, the compensator is slipping instead of catching and turning the crank.
Old Aug 17, 2015 | 12:55 AM
Next In Line
If the compensator was slipping, you would feel it when applying the throttle while the bike was in gear rolling down the road.
Is it doing that?
If yes - see service bulletin M-1170 before spending any money.
If no - (again) find a new dealer or a competent indy.
Old Aug 17, 2015 | 12:58 AM
Rodzilla6's Avatar
Rodzilla6
Unfortunately my Friend, I'm in the same boat as you...I have an 08 rocker with 49k (all mine so I know how it sounded/went when younger) and it's doing exactly the same thing you said, exactly. That is the same sound as you describe. Mine is intermittent, but becoming more frequent so I know it's in the plans for the future.
I will look at the options and replace it this winter. The Baker replacement sounds very interesting.
On the sound, I think it is created because the comp. is pushing back inappropriately so on the engine trying to start. Whatever it is, at least we know what it is and good options are available. Pretty easy to change also. I have been in there twice on my bike and it is not that hard to pull/install at all. Recently changed my stator, so comp had to come off. Follow the manual/easy.
I'll try to post my results.
Hope yours works out well.
Old Aug 17, 2015 | 09:29 AM
hattitude's Avatar
hattitude
OK... I think I get it now, it was me who misunderstood your explanation.
But still, the compensator wouldn't just slip on hot starts... I would think it would be slipping under load while riding, too.
Sounds like something else is going on instead of, or in addition to, a compensator problem.
I'd get another opinion before giving the dealer $$$. If you are capable of getting into the primary yourself, I'd take a look see....
Good luck
If you need a compensator, I have been following several threads, on two different forums, about the Baker Compensator... it seems to be a good option to the SE compensator!
brgtr3
Jan 26, 2025 06:56 AM
heavypic
Aug 30, 2008 01:56 AM
heavypic
Exhaust System Topics
Aug 28, 2008 05:13 PM
oiler2008
Apr 30, 2008 10:25 AM
bob1956wolf
16
Feb 7, 2008 08:40 AM
