Solenoid Starter Button
Old Aug 18, 2015 | 10:19 AM
Jon Grove's Avatar
Jon Grove
Stage II
Default Solenoid Starter Button
Has anyone successfully installed a Solenoid Starter button on a 2000 or later Fatboy? It seems that the oil line under the oil tank blocks access to the solenoid. I would love to have a backup for staring since on one of my cross country trip from Virginia my starter clutch crapped out just outside Olathe Kansas and I dont want to relive that day any time soon.
thanks for any response or pics of your install/modifications would be awesome.
Old Aug 18, 2015 | 02:52 PM
Tom84FXST's Avatar
Tom84FXST
Don't know about the oil line...but I do know the button will not help you if starter clutch is not working...FYI
Old Aug 18, 2015 | 03:56 PM
olongapo1's Avatar
olongapo1
I installed one on my 02 Fatboy. It's a tight space to work in but you will prevail if you just take your time.
Old Aug 18, 2015 | 04:22 PM
Fatboy1389's Avatar
Fatboy1389
I think you already have a no cost back up ...... it's called push, jump on, put it in 2nd gear and pop the clutch. Works even better when you have someone else do the push part -this method has worked for me many times
Old Aug 18, 2015 | 04:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
During the off season, I clean all the terminals in the starter circuit and the starter relay circuit. Never have had a starting problem, still have the original starter, although the relay is relatively new (it was replaced by the dealer under recall about 25 years ago...)
Old Aug 19, 2015 | 09:45 AM
panlvr's Avatar
panlvr
i installed it on my 94 heritage love it because it eliminates any electrical issues you have starting it with bad switch at the bars i wouldnt be without it now saved my *** a couple times
Old Aug 19, 2015 | 11:30 AM
back again's Avatar
back again
Been running one on my 05 since bigger motor was done. Tight under the oil line but usable. The Evo bikes are a straight shot.
Old Aug 19, 2015 | 03:10 PM
baloot-boy's Avatar
baloot-boy
I posted this a while back.
https://www.hdforums.com/forum/softa...er-button.html
HOGHIP
Apr 5, 2019 08:50 AM
scot210
Jun 30, 2014 09:09 PM
Boat drinks
Feb 1, 2013 09:06 AM
ritz
Oct 13, 2011 07:03 AM
Jameson
Sep 4, 2007 11:32 AM
