Wham!!!
Old Sep 3, 2015 | 11:53 AM
twiceretired's Avatar
twiceretired
Default Wham!!!
Well there I was, wondering aimlessly through the countryside, when WHAM, something blew. '07 Deuce with 36,000. Bike started bucking and clunking from the rear. First thought was the belt - like teeth had blown off. Wasn't the case. Next thought was the clutch, so trailered the bike home.
Put it on the lift and drained the primary and tranny fluids. Clean as a whistle. Not even fuzz on the magnets. Pulled the primary case and clutch. Everything looks good, and everything spins free with no lateral movement.
Headed out this morning to drop the rear wheel and pull the belt. Barring anything there, I'm leaning toward the tranny.
But would welcome any thoughts you may have.
Thanks,
Frank
Old Sep 3, 2015 | 12:32 PM
hvacgaspiping's Avatar
hvacgaspiping
Thanks,
Frank
Broken wheel hub bolt(s) and flew off as you rode?
Old Sep 3, 2015 | 05:42 PM
twiceretired
Angry
I believe I'm now a candidate for Dumbass of the Month (if not the year). I did pull the rear wheel and checked everything, including bearing and all attachments - all good. Peaked into the tranny and saw nothing but clean smooth gears. Really pleased with the wear.
Anyway, all I could figure is that the belt was too loose and jumping teeth. I tightened it up at the tight end of the limit, took it for a spin, and it ran just fine.
Old Sep 3, 2015 | 07:49 PM
MacKenzie001's Avatar
MacKenzie001
Dumbass or not, be happy with a cheap and easy fix.
Old Sep 3, 2015 | 07:54 PM
amkaos's Avatar
amkaos
Well good for your, good job
jworm1420
Jan 8, 2014 08:41 AM
sunuva
Nov 28, 2013 04:50 PM
defarmer
EVO
16
Nov 16, 2013 12:03 PM
CuzIam
Welcome Area Only
Nov 26, 2012 12:23 PM
hotrodrobert
Nov 5, 2006 12:12 AM
